The name 'pwmPhaseB1' does not exist in the current context
hi every one
I work with a projeckt where I need to use PWM and ADC channal .
The project works, but would like to reuse class to another motor.
This is probably a beginner’s question. But how can I do this without error
The name ‘pwmPhaseB1’ does not exist in the current context
MotorDriver MotorPan = new MotorDriver(4,6,5,7,9,20000,false); // in the main
MotorPan.Drive(true); // use the drive algoritme
class MotorDriver
    public MotorDriver(int pinPhaseA1, int pinPhaseA2, int pinPhaseB1, int pinPhaseB2, int pinVref, int Freq, bool Invert)
            PWM pwmPhaseA1 = new PWM((Cpu.PWMChannel)pinPhaseA1, Freq, 0.0, Invert);
            PWM pwmPhaseA2 = new PWM((Cpu.PWMChannel)pinPhaseA2, Freq, 0.0, Invert);
            PWM pwmPhaseB1 = new PWM((Cpu.PWMChannel)pinPhaseB1, Freq, 0.0, Invert);
            PWM pwmPhaseB2 = new PWM((Cpu.PWMChannel)pinPhaseB2, Freq, 0.0, Invert);
            PWM pwmVref = new PWM((Cpu.PWMChannel)pinVref, 100000, 0.0, Invert);
    public void Drive(bool dir)
            pwmPhaseA1.DutyCycle = pwmValues[0];
            pwmPhaseA2.DutyCycle = pwmValues[1];
            pwmPhaseB1.DutyCycle = pwmValues[2];
            pwmPhaseB2.DutyCycle = pwmValues[3];
@ andre.m
Yes it is true, but Drive and MotorDriver are in the same class.
How do at get access to the pwmPhase* in the other methods, that are in the same class?
:think:
@ andre.m
Thanks for your reply :slight_smile:
when i try your example in my code, are there no error from the IDE.
But the program crash on the G120HDR, first time there are a PWM DutyCycle update.
Following exception:
Do you know why this is happens???
Hi again :wink:
I have worked with it for several hours without success.
I chose to create a new project, where I have only made ​​pwm setup and dutycycle update.
But the same exception appeared.
using System.IO;
using GHI.Hardware.G120;
using GHI.Premium;
using GHI.Premium.System;
namespace PWMsetup_test
            PWM_setup MotorPan = new PWM_setup(0, 20000, false);
                MotorPan.Update();
    class PWM_setup
        PWM pwmPhaseA1;
        public PWM_setup(int pinPhaseA1, int Freq, bool Invert)
        public void Update()
            pwmPhaseA1.DutyCycle = 0.2;
            Thread.Sleep(100);
            pwmPhaseA1.DutyCycle = 0.8;
            Thread.Sleep(100);
Is there a similar way to do this?
first pwm update
It seems like there are no access in “update”
Look at comment in code
        PWM pwmPhaseA1;
        public PWM_setup(int pinPhaseA1)
            PWM pwmPhaseA1 = new PWM((Cpu.PWMChannel)pinPhaseA1, 20000, 0.0, false);    // =0.0
            pwmPhaseA1.DutyCycle = 0.5;     // =0.5
            pwmPhaseA1.DutyCycle = 0.2;   // = NULL and break
            Thread.Sleep(100);
            Thread.Sleep(100);
The PWM you declared in PWM_setup shadowed the global PWM inside the function, so the global one was never set, only a temporary local one was. The below code fixes that.
PWM pwmPhaseA1;
             Thread.Sleep(100);
             Thread.Sleep(100);
@ John
yes just find out 10 min ago :whistle:
Tak for all your time and help
@ andre.m
@ John
