I’ve actually found that intelligent wireless modules, like the xbee stuff, do pretty well with networking, although the drivers are quite a bit of effort to create.
I haven’t had great experiences just hooking netmf ethernet up to a networking. It seems to get flooded too easily unless you isolate the device.
Note that I haven’t tried the Gadgeteer wireless module yet (don’t have one), but I have tried hard-wired ethernet.
When you say “flooded” what do you mean? If you’re on a switched network, there shouldn’t be any traffic on the wire that’s not destined for your device anyway…
I mean the device has to analyze too many broadcast packets. Even on a switched network, there’s a lot of junk being thrown around on the wires.
You can usually work around this by putting the NETMF device and, if you’re looking at essentially a point to point connection, the other device on the same switch and subnet, separated from the rest of the network.
Note, at home, most folks won’t run into this unless there’s a lot of network management junk on the network.
