Hello all community,
Here’s how I do to send data in my database with the GET method. But it does not add.
As soon as you have an idea?
C# CODE
namespace Wifi
public partial class Program
if (Startwifi())
ReqGet();
bool Startwifi()
if (wifi_RS21 != null)
if (wifi_RS21.Interface.IsOpen)
wifi_RS21.Interface.Disconnect();
string SSID = "SGC";
string password = "TechCFPT_2012";
bool conn = false;
wifi_RS21.Interface.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(wifi_RS21.Interface);
WiFiNetworkInfo[] infos = wifi_RS21.Interface.Scan();
foreach (WiFiNetworkInfo info in infos)
if (info.SSID == SSID)
wifi_RS21.Interface.NetworkInterface.EnableDhcp();
wifi_RS21.Interface.Join(info, password);
Debug.Print(SSID + " Connected");
conn = true;
break;
conn = true;
Debug.Print(SSID + " not found");
return conn;
void ReqGet()
string finalUri = "http://albentrix.com/fez.php?value=20";
HttpWebRequest request = (HttpWebRequest)HttpWebRequest.Create(finalUri);
HttpWebResponse rsponse = (HttpWebResponse)request.GetResponse();
Debug.Print("ReqGet OK");
PHP CODE
<?php
require 'id.php';
mysql_connect($dbhost, $dbuser, $dbpassword) or die(mysql_error());
mysql_select_db("134387_ecole") or die(mysql_error());
mysql_query("INSERT INTO fez (current) VALUES (" .$_GET['value']. ")") or die(mysql_error());
