Announced recently, the G30HDR, a very small trough-hole version of the surface-mount G30 System on Chip. This allows for an easy way to wire and build projects. It is also DIP format compatible. A socket can be used to plug the G30HDR onto boards instead of soldering. OF course, the male headers must be added first.
As for power, the base microcontroller, the STM32F401, is extremely low power. The G30HDR is designed with no regulator to give the user options when it comes to choosing the right power supply. Especially that STM32F401 can run on voltages lower than 3.3V. The datasheet from ST would cover full details on power consumption and operating voltages.
To power the G30HDR from the USB port, the VBUS signal is exposed on one of the pads. This is the voltage coming from the USB port. This can be used to feed the 3.3V power regulator that feeds the entire system, including the G30HDR itself. As another option, the G30HDR includes the footprint for a regulator that is intentionally left not populated. At 100 pcs or more, the G30HDR can be ordered with the regulator added. However, this regulator is not suited for lower power applications, hence not populated.
Finally, customers can even select to order the G30HDR with headers pre-installed as well.
