The first falling edge after a reset on PIN PD7 (PE3, PB7, …) does not cause an interrupt. Why?
Tested on SM20260D Dev and custom board with SCM20260N. FW 2.2.0.61
var gpio = GpioController.GetDefault();
var button = gpio.OpenPin(SC20260.GpioPin.PD7);
button.SetDriveMode(GpioPinDriveMode.InputPullUp);
button.ValueChangedEdge = GpioPinEdge.FallingEdge | GpioPinEdge.RisingEdge;
button.ValueChanged += Button_ValueChanged;
button.DebounceTimeout = TimeSpan.FromMilliseconds(50);
void Button_ValueChanged(GpioPin sender, GpioPinValueChangedEventArgs e)
if (e.Edge == GpioPinEdge.FallingEdge)
Debug.WriteLine("Pin went low");
Debug.WriteLine("Pin went high");
Digital input events rely on internal GPIO interrupts to work. On SITCore, these interrupts are only available on 16 pins at any given time, the pin number must be unique, over all of the available ports. For example: PA1 and PB1 cannot both be used as interrupts at the same time. However, PA1 and PB2, or even PA1 and PA2, can be used simultaneously.
Consider other internal system functions that need interrupts, such as WiFi. Those also reserve one of the 16 available interrupts.
In our case we are using it to wake the app up when a user presses a button, if it doesn’t wake the first time they will just press again so no big issue, but annoying.
On the other hand the “random” failure to wake on RTC depending on actual time, which seems to be due to an internal math error, is currently a real show-stopper for us
