Hello guys,
when using Fez Spider sometimes the Debugger fails to get attached, and i just can’t find the cause to this; and it is driving me nuts…
anyone experienced this kind of problem?
i also noticed if i put a break and try to debug while the debugger fails to get attached VS stops the debugger and show the following error: the Break work in the hardware because i can see that the hardware isn’t moving past the break.
The debugger engine failed to receive any debug events from the debugging target
hmm it is a Gatgeteer application and all i have a simple Led calls in the ProgramStarted()…
i even tried thread.Sleep(1000); at the very beginning and it didn’t help…
notice that sometime it works just fine.
well i did have a foreach loop that just loops through an Object and prints the properties … that could be it… after adding a Thread.Sleep(10); inside the loop it looks like it worked…
so the question is DO I NEED THAT Thread.Sleep(10); if I’m not doing the debug ? or only use it when debugging…
i guess this should be added to the Tips… anytime one uses a for loop should consider adding the Thread.Sleep(); inside the loop for debugging purposes…
Hi Mike,
thanks for checking in… i hope you had great holidays. mine are just coming up ;).
as for the issue no not really,
it just happens randomly…so i can’t really pin point the issue…
and to eliminate the issue i switch to the emulator, because i got tired of having to restart the debugger three to four time before it hooks…
what i found out that works most of the time: is
clean the solution>>Rebuild the solution>>start the debugger… doing these steps seems to make it work…
not sure why… but not all the time though.
