I enabled the network on the endpoint, and I’m trying to debug over the new IP address x.x.1.79, but the debugger keeps asking about the configuration for root@192.168.82.2
I’m not sure how we solved this problem before.
Did you change the IP address in the endpoint debugger project options?
Yes I changed that IP to 192.168.1.79
Have you tried a new project?
I made a new project, and it works now. We have encountered this problem before, but I can’t find it on the forums.
Close VS and reopen may work. The extension cached information somewhere.
Or clean build, delete .vs folder also help.
