Hello Gents,
Since the documentation on your page is empty I would like to ask about some examples for display.
http://docs.ghielectronics.com/tinyclr/tutorials/display.html
Can you send me some information or examples that allow me to use TFT SPI display on G80 (0.5 firmware)
I was not able to find full example on forum ;/
Best Regards,
PG
You said it, SPI display. That is simply SPI.
Also, you listed your topic under NETMF but you link to TinyCLR. Wich system are you using?
Sorry it should be tinyclr :). I saw display in libraries and also I saw that on one of your board with G80 you are using display LCD TFT . I thought that you have got already created libraries and I will be able to use them just by invoking lcd.write(“Hello world”) or something like that
A SPI display is simply SPI to TinyCLR. Each display will likely to have a different way to working. Do you have a display? Which board are you using? You have us zero information.
The second one uses the same display as
http://docs.ghielectronics.com/tinyclr/accessories/adafruit_display_shield.html
The code is done but needs to be cleaned up and posted.
Nice
Can you share with an information when it will be available ?
