Text on TFT display Fez Cobra
Hello,
I have an Fez Cobra and have conntected an 4.3" TFT screen. The screen is working because the startup logo is showing on the screen.
But how can i place a simple text on the screen like: Hello World
i made a new bitmap example: Bitmap LCD = new Bitmap(Symetric.Width,Symetrc.Height) and then use:
LCD.Clear();
LCD.Drawtext(“Hello World”,MyFont, Colors.Red, 100,100);
LCD.Flush();
But this does not seems to work.
What excatly do not work? Do you receive some error?
Have you tried to draw a line to see if the problem is related to text only or any drawing operations?
Step in code line by line, use F10
When step in the code you see nothing happend on the LCD screen, the start-up logo stay and no text is added.
The way I use now is this:
public Window CreateWindow()
// Create a window object and set its size to the
// size of the display.
mainWindow = new Window();
mainWindow.Height = SystemMetrics.ScreenHeight;
mainWindow.Width = SystemMetrics.ScreenWidth;
// Create a single text control.
text = new Text();
text.Font = Resources.GetFont(Resources.FontResources.Arial48Bold) ;
text.TextContent = Resources.GetString(Resources.StringResources.String1);
text.HorizontalAlignment = Microsoft.SPOT.Presentation.HorizontalAlignment.Center;
text.VerticalAlignment = Microsoft.SPOT.Presentation.VerticalAlignment.Center;
// Add the text control to the window.
mainWindow.Child = text;
// Set the window visibility to visible.
mainWindow.Visibility = Visibility.Visible;
        return mainWindow;
But that I don’t like, I like something simpler.
If help you I use something like this and work normaly:
namespace Test
    class LCD
        public Bitmap LCDPanel = new Bitmap(SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight);
        Font SegoeUI12Bold = Resources.GetFont(Resources.FontResources.segoe_ui_12_bold);
        public LCD()
            LCDPanel.Clear();
            LCDPanel.Flush();
        public void ShowMessage(string text)
            LCDPanel.Clear();
            LCDPanel.DrawText(text, SegoeUI12Bold, Colors.White, 0, LCDPanel.Height-SegoeUI12Bold.Height-5);
            LCDPanel.Flush();
namespace Test
    public class Test
            LCD lcd = new LCD();
			lcd.ShowMessage("LCD Show some text");
SegoeUI12Bold is font you can use small or NinaB font.
Maybe we’re missing something obvious like the bitmap not being the right size. If it’s not exactly the size of the LCD it will not flush. Try replacing SystemMetrics with a hardcoded value.
Thank you it works!!
I did use the example of Dejan and I can put screen on the display. Now looking how i can place text with coordinates.
Kind regards!
