Am I doing something wrong? I have connected my Fez Domino to a DB9 shield, then connected that to a COM port on my computer. I open up TerraTerm, and see the new COM port, so I choose it and connect to it (COM5 on computer). After that, I see nothing, i can’t type or anything. I was able to get my Fez Domino working with a loop/jumper. Is there something special I have to do?
Have you set the Tera Term Terminal Setup like in the picture??
Yes I do. One thing I noticed based on your image, is when I send a string, do I need to add “\n” after the string to send a carriage return (CR) ?
This is my function for sending data via COM port:
static void send(String msg)
tx_data = Encoding.UTF8.GetBytes(msg); //get file
// flush all data
UART.Flush();
// send some data
UART.Write(tx_data, 0, tx_data.Length);
// wait to make sure data is transmitted
Thread.Sleep(100);
you can set the Transmit to CR+LF so you don’t need to add \n
Have you try to use the example in the eBook, from the download page?
http://www.tinyclr.com/downloads/Beginners%20guide%20to%20NETMF.pdf
17.1 UART page 76
Could not tell from the code snippet, what you want to do exactly.
Thanks for your recommendation. However, when I try the sample code, this is the output i get…
Good progress. Now make sure the baudrate in teratem is the same. I see in your code it is 115200
Oh man, how could I be so forgetful! I really appreciate your help and patience. I’m really kicking myself right now for not even checking that…how embarrassing! But either way… Thank you!
I did the exact mistake when I first learnt UART.
I think basically everyone has fallen into that pitfall at some point or another. I know I have. Don’t feel too bad
…but always assume the answer to your first question is “Yes”
