Tech Talk with Gus 11 - TinyCLR Preview Release
Today we’ll talk about the Preview Release of TinyCLR-OS
:clap:
To learn more and download TinyCLR OS:
[url]https://www.ghielectronics.com/community/forum/topic?id=24044[/url]
TinyCLR code for Sparkfun Studio Spectrum Shield with Strip LEDs.
using System.Diagnostics;
using GHIElectronics.TinyCLR.Devices.Adc;
namespace SpectrumShield
        static LedStripLPD8806 mLedStrip;
        const int LED_INTENSITY = 2;
        static Random mRandom = new Random();
        const int NUM_LEDS = 56;
        static GpioPin ResetPin;
        static GpioPin Strobe;
        static AdcChannel Ain;
        static double[] Frequencies_One = new double[7];
            var Adc = AdcController.GetDefault();
            Ain = Adc.OpenChannel(FEZPandaIII.AnalogInput.A0);
            var gpio = GpioController.GetDefault(); /* Get the default GPIO controller on the system */
            Strobe = gpio.OpenPin(FEZPandaIII.Gpio.D4);
            Strobe.Write(GHIElectronics.TinyCLR.Devices.Gpio.GpioPinValue.High);
            Strobe.SetDriveMode(GHIElectronics.TinyCLR.Devices.Gpio.GpioPinDriveMode.Output);
            ResetPin = gpio.OpenPin(FEZPandaIII.Gpio.D5);
            ResetPin.Write(GpioPinValue.High);
            ResetPin.SetDriveMode(GHIElectronics.TinyCLR.Devices.Gpio.GpioPinDriveMode.Output);
            Thread.Sleep(5000);
            //Initialize Spectrum Analyzers
            Strobe.Write(GHIElectronics.TinyCLR.Devices.Gpio.GpioPinValue.Low);
            Thread.Sleep(1);// delay(1);
            ResetPin.Write(GHIElectronics.TinyCLR.Devices.Gpio.GpioPinValue.High);
            Thread.Sleep(1);//delay(1);
            Strobe.Write(GpioPinValue.Low);
            ResetPin.Write(GpioPinValue.Low);
            mLedStrip = new LedStripLPD8806(NUM_LEDS);
            Debug.WriteLine("starting...");
                Read_Frequencies();
                Graph_Frequencies();
        static void Read_Frequencies()
            //Read frequencies for each band
            for (int i = 0; i < 7; i++)
                Frequencies_One[i] = Ain.ReadRatio();// analogRead(DC_One);
                Strobe.Write(GpioPinValue.High);
        static void Graph_Frequencies()
                switch ((int)(7 * Frequencies_One[i]))
                    case 1:
                        mLedStrip.Set(0 + (8 * i), 0, LED_INTENSITY, 0);//GREEN
                        break;
                    case 2:
                        mLedStrip.Set(1 + (8 * i), 0, LED_INTENSITY, 0);//GREEN
                        break;
                    case 3:
                        mLedStrip.Set(2 + (8 * i), 0, LED_INTENSITY, 0);//GREEN
                        break;
                    case 4:
                        mLedStrip.Set(3 + (8 * i), 0, LED_INTENSITY, 0);//GREEN
                        mLedStrip.Set(4 + (8 * i), LED_INTENSITY/2, LED_INTENSITY/2, 0);//YELLOW
                        break;
                    case 5:
                        mLedStrip.Set(5 + (8 * i), LED_INTENSITY/2, LED_INTENSITY/2, 0);//YELLOW
                        break;
                    case 6:
                        mLedStrip.Set(6 + (8 * i), LED_INTENSITY, 0, 0);//RED
                        break;
                    case 7:
                        mLedStrip.Set(7 + (8 * i), LED_INTENSITY, 0, 0);//RED
                        break;
                    default:
                        mLedStrip.Set(0, 0, 0);
                        break;
        static void FlashTest(object o)
            for (int test = 0; test < 3; test++)
                int r = test == 0 ? 32 : 0;
                int g = test == 1 ? 32 : 0;
                int b = test == 2 ? 32 : 0;
                mLedStrip.Set(r, g, b);
                Thread.Sleep(250);
            mLedStrip.TurnOff();
LedStripLPD8806 Class:
using GHIElectronics.TinyCLR.Devices.Spi;
public class LedStripLPD8806
    /// <summary>this LPD8806 wants every byte to have 0x80 on, for some reason</summary>
    private const byte MASK = 0x80;
    /// <summary>AND'ed in to get the real color component out</summary>
    private const byte UNMASK = 0x7F;
    /// <summary>number of LEDs in our strip</summary>
    private readonly int mNumLeds;
    /// <summary>number of bytes used for the strip (mNumLeds * 3)</summary>
    private readonly int mLedByteCount;
    /// <summary>LED data plus unlatch bytes</summary>
    private byte[] mData;
    /// <summary>true if the user doesn't want to push data to the strip yet</summary>
    private bool mUpdating;
    /// <summary>the SPI object for the strip itself</summary>
    private SpiDevice mLedStrip;
    public LedStripLPD8806(int numLeds)
        mLedStrip = SpiDevice.FromId("SPI2", new SpiConnectionSettings(FEZPandaIII.Gpio.A1)
        { ClockFrequency = 2000000, Mode = SpiMode.Mode0, DataBitLength = 8 });
        int latchBytes = ((numLeds + 63) / 64) * 3;
        mLedByteCount = numLeds * 3;
        mData = new byte[mLedByteCount + latchBytes];
        mNumLeds = numLeds;
        // start with all the LEDs off
        for (int i = 0; i < mLedByteCount; i++)
            mData[i] = MASK;
        // give the strip an inital poke of the latch bytes (no idea
        // why this is needed)
        mLedStrip.Write(new byte[latchBytes]);
        // push the initial values (all off) to the strip
        SendUpdate();
    /// <summary>
    /// pushes the colors to the strip, if we're not doing an update
    /// </summary>
    public void SendUpdate()
        if (!mUpdating)
            mLedStrip.Write(mData);
    /// <summary>
    /// turns off a particular LED
    /// </summary>
    /// <param name="index">which LED (0-based) to turn off</param>
    public void TurnOff(int index)
        int i = index * 3;
        mData[i + 0] = MASK;
        mData[i + 1] = MASK;
        mData[i + 2] = MASK;
        SendUpdate();
    /// <summary>
    /// Turns off the entire LED strip
    /// </summary>
    public void TurnOff()
        for (int i = 0; i < mLedByteCount; i += 3)
        SendUpdate();
    /// <summary>
    /// gets or sets a particular LED RGB color value
    /// </summary>
    /// <param name="index">the LED in question</param>
    /// <returns>the RGB (not BRG) colors in the lower 24 bits</returns>
    public int this[int index]
        get
            int i = index * 3;
            int g = (mData[i + 0] & UNMASK);
            int r = (mData[i + 1] & UNMASK);
            int b = (mData[i + 2] & UNMASK);
            // NB: returning RGB, not BRG
            int color = r << 16 | g << 8 | b << 0;
            return color;
        set
            Set(index, value >> 16, value >> 8, value);
    /// <summary>
    /// sets a particular LED to a color (0-127 for each color)
    /// </summary>
    /// <param name="index">the LED to set</param>
    /// <param name="red">the red value for the LED</param>
    /// <param name="green">the green value for the LED</param>
    /// <param name="blue">the blue value for the LED</param>
    public void Set(int index, int red, int green, int blue)
        int i = index * 3;
        mData[i + 0] = (byte)(MASK | green);
        mData[i + 1] = (byte)(MASK | red);
        mData[i + 2] = (byte)(MASK | blue);
        SendUpdate();
    /// <summary>
    /// sets all LEDs in the strip to a particular color
    /// </summary>
    public void Set(int red, int green, int blue)
        SendUpdate();
Very cool. I love that it is all based on NEW stuff - VS2017. Not 4 year old versions. Thanks!
I got it working last night with a G80TH :smiley:
@ Greg Norris -
I have searched but I could not find anything about where to source the Seeed Studio Spectrum Shield.
Do you have a part number or other info?
Thank You!
@ cyberh0me -
sparkfun spectrum
That is what I thought but I was not sure.
@ willgeorge -
cyberh0me is correct it is the Spark Fun Shield he posted the link too.
