We try to keep all that under individual tutorials. If there are missing info then we are here to answer your questions and improve the docs.
And yes you are right, some questions are answered by the STM32 datasheet, like the value of internal pull up resistor. But others need to be answered by us, like what is the PWM range.
I am curious on what you are building that you need to know the pull up value and need the limits of PWM. Can you share?
There is nothing particular about knowing the pwm range or pull up value, it was given just as an example of some recent questions i had when i was trying to determine the capability of the pwm, or try to predict how much of a burden the pull ups would be on a battery application. Its kind of basic design info to have I believe.
More than anything i do a lot of everything, so its best for me to understand the capabilities so i do not need as much trial and error or proof of concept.
That said, ive been all over the pwm tutorial and do not see such detail.
I do see properties to retrieve these during run time, I would just like to have these basic details on hand. Besides which i do not actually have all devices i would like for trial and error…
That said, i dont mind telling you I am currently working on a vehicle management computer. I know that is a rather generic description, but until i get something working, there really isn’t much to brag about.
I spent the last several days chasing down a bug, where the issue appears to be that there is an arbitrary default Gpio DebounceTimeout set to input pins.
Again I find that when an arbitrary values are in play, if such information is not presented in online documentation (i always check the online documentation) General Purpose Input Output (GPIO)
Then I for one tend to design without it, and run into these silly problems.
Of course a solution is to simply probe the device and check for these things before hand, but that is a poor substitution for a document
When a mechanical button is pressed it generates multiple edges that are caused by the contact physically bouncing. The built in debounce feature filters out any edges coming in faster than a specific time, which is set to 20ms be default. The debounce value can be changed using software.
Yes thanks to @Mike snide remarks I was compelled to reread the tutorial until I uncovered the data for myself.
Though first digging through the libraries source there seems no mention of it as was implied.
maybe it’s just me but I prefer the datasheet/table format to uncovering quantitative data rather than finding it in story format. But will take what I can get. Thank you
