TE35 Display Module question regarding SHDN#
Hi everyone,
I have a question regarding pin SHDN# for the TE35 Display Module. This apparently has to do with a Shutdown mode, correct? Is it an input or an output? If it’s an input and it’s not used, should it be floating, tied to Vcc or tied to ground?
http://www.ghielectronics.com/catalog/product/387
Thank you.
It is pulled up high though a pull-up resistor. Set it to LOW in code to shut down the display.
Thank you.
You are welcome!
