Hi everyone,
i’m trying to build a client server application using Fez Spider as Client and a console .Net application as server. The main issue on the socke.Send. The device results as connected, after a while a make a send call on the socket but I’ve ALWAYS the SocketError =10053.
I’ve disabled firewall, antivirus and all possible stuff but the problem does not change. I post the code for client and server
ServerSide
using System.Net;
using System.Net.Sockets;
using System.Text;
namespace SimpleServer
public class SynchronousSocketListener
// Incoming data from the client.
public static string data = null;
public static void StartListening()
// Data buffer for incoming data.
byte[] bytes = new Byte[1024];
// Establish the local endpoint for the socket.
// Dns.GetHostName returns the name of the
// host running the application.
IPAddress ServerIP = new IPAddress(new byte[] { 192, 168, 1, 3 });
IPEndPoint localEndPoint = new IPEndPoint(ServerIP, 7777);
// Create a TCP/IP socket.
Socket listener = new Socket(AddressFamily.InterNetwork,
SocketType.Stream, ProtocolType.Tcp);
// Bind the socket to the local endpoint and
// listen for incoming connections.
try
listener.Bind(localEndPoint);
listener.Listen(100);
// Start listening for connections.
Console.WriteLine("Waiting for a connection...");
Console.WriteLine(ServerIP.ToString());
Thread.Sleep(1000);
// Program is suspended while waiting for an incoming connection.
Socket handler = listener.Accept();
data = null;
if (handler.Connected)
Console.WriteLine("Connected");
// An incoming connection needs to be processed.
bytes = new byte[1024];
int bytesRec = handler.Receive(bytes);
data += Encoding.ASCII.GetString(bytes, 0, bytesRec);
if (data.IndexOf("4") > -1)
break;
// Show the data on the console.
Console.WriteLine("Text received : {0}", data);
// Echo the data back to the client.
byte[] msg = Encoding.ASCII.GetBytes(data);
handler.Send(msg);
handler.Shutdown(SocketShutdown.Both);
handler.Close();
catch (Exception e)
Console.WriteLine(e.ToString());
Console.WriteLine("\nPress ENTER to continue...");
Console.Read();
public static int Main(String[] args)
StartListening();
return 0;
Simple client
using System.Collections;
using Microsoft.SPOT.Touch;
using System.IO;
using System.Net;
using System.Text;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerClientTest
public partial class Program
Debug.Print("Program started");
if (!ethernetJ11D.NetworkInterface.Opened)
Debug.Print("Opening interface");
ethernetJ11D.NetworkInterface.Open();
Debug.Print("Interface opened");
ethernetJ11D.UseStaticIP("192.168.0.8", "255.255.255.0", "192.168.0.1");
Socket socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
IPEndPoint endpoint = new IPEndPoint(IPAddress.Parse("192.168.1.3"), 7777);
ethernetJ11D.UseThisNetworkInterface();
new Thread(() =>
try
Thread.Sleep(3000);
PrintNetworkState();
Debug.Print("Connecting socket");
socket.Connect(endpoint);
Debug.Print("Socket connected");
byte[] msg = new byte[] { 0, 1, 2, 3, 4 };
socket.Send(msg);
catch (SocketException e) { Debug.Print("SocketException: " + e.ErrorCode); }
catch (Exception e) { Debug.Print(e.GetType().ToString() + ": " + e.Message); }
finally { PrintNetworkState(); }
}).Start();
void PrintNetworkState()
StringBuilder builder = new StringBuilder();
builder.Append("Up=");
builder.Append(ethernetJ11D.IsNetworkUp);
builder.Append("; ");
builder.Append("Connected=");
builder.Append(ethernetJ11D.IsNetworkConnected);
builder.Append("IP=");
builder.Append(ethernetJ11D.NetworkInterface.IPAddress);
builder.Append("Mask=");
builder.Append(ethernetJ11D.NetworkInterface.SubnetMask);
builder.Append("GW=");
builder.Append(ethernetJ11D.NetworkInterface.GatewayAddress);
Debug.Print(builder.ToString());
