I just posted Unable to set SSL seed using FEZ Config on Task Tracker. Feel free to discuss and make suggestions here.
Unable to set SSL seed using FEZ Config was updated.
Status went from Proposed to Open.
Priority went from Unassigned to Trivial.
Status went from Open to Closed.
Is this a security vulnerability? Does this mean that the same SSL seed is chosen every time?
@ godefroi - You still have to use MFDeploy to set the seed.
Oh, I see, it can be changed, but not with FEZ Config.
@ godefroi - Correct.
