I just posted Adding a Search to the Task Tracker on Task Tracker. Feel free to discuss and make suggestions here.
Adding a Search to the Task Tracker was updated.
Status went from Proposed to Open.
Priority went from Unassigned to Trivial.
@ Josh - how is trivial a priority? it is an estimate of effort.
The point here was to make it open with the lowest priority so it can be voted upon. The priorities are as follows: Critical, Major, Minor and Trivial. The priorities were based off a similar software we use. Trivial means of little value or importance.
Ah, you used the pejorative meaning of trivial.
It’s not that I don’t see it as important, but its/our priority will be based on votes. Right now the lists are small and navigable so it doesn’t need immediate attention. If things go well it will be added.
