Hello All,
I’m using FEZ Cerbot and Distance US3 module to do obstacle detection, I used same code shared by twkisner
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace Cerbot
public partial class Program
multicolorLed.GreenBlueSwapped = true; //my RGB LED has the blue and green flipped
// plays the scale
cerbotController.StartBuzzer(261, 600);
cerbotController.StartBuzzer(293, 600);
cerbotController.StartBuzzer(329, 600);
cerbotController.StartBuzzer(349, 600);
cerbotController.StartBuzzer(392, 600);
cerbotController.StartBuzzer(440, 600);
cerbotController.StartBuzzer(493, 600);
cerbotController.StartBuzzer(523, 600);
char_Display.PrintString("William's Cerbot");
new Thread(RobotEyeSlide).Start();
new Thread(DoEdgeDetect).Start();
void RobotEyeSlide()
ushort Eyes = 0;
int direction = 1;
int ledIndex = 0;
ledIndex += direction;
Eyes = (ushort)(0x1 << ledIndex);
cerbotController.SetLEDBitmask(Eyes);
Thread.Sleep(30);
if (ledIndex <= 0 || ledIndex >= 15)
direction *= -1;
void DoEdgeDetect() //does edge detect and distance with US3
const int RUN_SPEED = 70;
const int REVERSE_SPEED = -70;
distance_US3.AcceptableErrorRate = 0;
int j;
const double SENSOR_THRESHOLD = 10;
Thread.Sleep(1);
bool leftOverEdge = cerbotController.GetReflectiveReading(CerbotController.ReflectiveSensors.Left) > SENSOR_THRESHOLD;
bool rightOverEdge = cerbotController.GetReflectiveReading(CerbotController.ReflectiveSensors.Right) > SENSOR_THRESHOLD;
if (!rightOverEdge && !leftOverEdge)
//if it detects edges, stops
multicolorLed.TurnColor(GT.Color.Red);
cerbotController.SetMotorSpeed(0, 0);
cerbotController.StartBuzzer(1000, 100);
char_Display.SetCursor(1, 0);
char_Display.PrintString("Put Cerbot Down!");
Thread.Sleep(2000);
Thread.Sleep(100);
j = distance_US3.GetDistanceInCentimeters(5);
if (j == distance_US3.SENSOR_ERROR)
char_Display.PrintString("Sensor error");
char_Display.PrintString("Distace away=" + j);
if (j <= 5 || j >= 40)
multicolorLed.TurnColor(GT.Color.Cyan);
cerbotController.SetMotorSpeed(RUN_SPEED, RUN_SPEED);
//if it detects object within 40 centimetes, stops, backs up, turns, beeps then goes forward
multicolorLed.TurnColor(GT.Color.Magenta);
cerbotController.SetMotorSpeed(REVERSE_SPEED, REVERSE_SPEED);
Thread.Sleep(250);
cerbotController.SetMotorSpeed(REVERSE_SPEED, RUN_SPEED);
Thread.Sleep(500);
cerbotController.StartBuzzer(2000, 500);
The code works good and able to detect obstacles .
Now I’m trying to do target detection e.g red circle on the floor as a target, and the robot has to stop when reaches this target
Can you please assist me on modifying the code and the other modules should I use ?
King regards
Sara
