I just wondered if anyone had any Visual Basic code they would be willing to share using the T43 Display with touch to make onscreen menu buttons/options. I have no problems using the display but just a bit of example code of tieing the touch up with the actual display would be greatly appreciated.
If you are familiar with VB you should consider switching to C# as most, if not all, drivers and samples are in C#. Coming from VB and C/C++ myself, the switch to C# was quite a lot easier than I expected. With the code complete in VS2012 it is quite easy to get up and running in C#.
If you can do this, Glide offers you a free GUI for working with the LCD’s and is easy to work with. For a paying option, CLIX2 from Skewworks is recommended.
