When you run the write step in IFU, it actually only buffers the firmware internally and nothing is written on flash. This should be explained in docs I believe
SystemUpdate.SystemUpdateMode mode = SystemUpdate.GetMode();
Log("EMX starts. Mode: " + mode.ToString());
// Allow firmware on the board to be upgradable.
if (mode == SystemUpdate.SystemUpdateMode.NonFormatted)
SystemUpdate.EnableBootloader();
// Force a hard reboot
PowerState.RebootDevice(false);
// Start to upgrade firmware
if (mode == SystemUpdate.SystemUpdateMode.Bootloader)
Log("Start to upgrade ...");
// Force mount all removable disks
if (firmwarePath.Length > 0)
// Start to upgrade
try
SystemUpdate.ApplicationUpdate.Start();
FileStream fs = new FileStream(firmwarePath, FileMode.Open, FileAccess.Read);
byte[] buffer = new byte[10 * 1024];
int len = 0;
do
len = fs.Read(buffer, 0, buffer.Length);
SystemUpdate.ApplicationUpdate.Write(buffer, 0, len);
throw new Exception(); // throw an exception to interrupt updating
} while (len == buffer.Length);
SystemUpdate.ApplicationUpdate.End();
catch (Exception ex)
Log("Failed to upgrade.");
//Restart
SystemUpdate.AccessApplication();
if (mode == SystemUpdate.SystemUpdateMode.Application)
if (PersistentStorage.DetectSDCard())
PersistentStorage ps = new PersistentStorage("SD");
ps.MountFileSystem();
if (File.Exists("\\SD\\Firmware.hex"))
Log("Prepare to upgrade. Rebooting ...");
SystemUpdate.AccessBootloader();
Thread.Sleep(5000);
I write the code above in main function. It reads firmware from a micro SD card and upgrade it to the EMX board. I use an exception in write loop to interrupt the upgrading. The firmware size is 260+ KB, so in my code it only write 10KB to EMX.
After I reboot the EMX board, I can see a debug message from MFDeploy:
This is the version. You have succeeded to upgrade the firmware.
This message is the only Debug.Print message of the firmware in SD card.
In ApplicationUpdate:
Once you hit Start(), the main application is erased.
There is no rollback option, but you should NOT call AccessApplication mode until everything is updated correctly.
So when a failure happens during transferring the application, simply reboot the device and it will go into bootloader mode or call End() then Start() again to re-update…
In CompleteUpdate it is different. Nothing is updated until you call End().
From my test, I believe CompleteUpdate.Start() erases the main application either. I use CompleteUpdate instead of ApplicationUpdate in my code, after a fail update, I get the message from MFDeploy:
Ready.
Cannot find any entrypoint!
Done.
Waiting for debug commands…
No debugger!
If I use ApplicationUpdate, the message from MFDeploy is:
Ready.
Hello, this is the new version. …
No, I threw an exception in loop Write() method, it never goes to End() method. The new code is the same as my code above, just use ComplateUpdate instead of ApplicationUpdate.
