A first chance exception of type 'System.OutOfMemoryException' occurred in mscorlib.dll
An unhandled exception of type 'System.OutOfMemoryException' occurred in mscorlib.dll
This is the code I’m using for the Mood Cube project I just put up:
using GT = Gadgeteer;
namespace MoodLight
public partial class Program
int i = 0;
int direction = 1;
int color = 0;
multicolorLed.GreenBlueSwapped = true;
GT.Timer timer = new GT.Timer(5);
timer.Start();
// Debug.Print("i: " + i);
switch (color)
case 0:
multicolorLed.SetBlueIntensity(i);
break;
case 1:
multicolorLed.SetGreenIntensity(i);
break;
case 2:
multicolorLed.SetRedIntensity(i);
break;
if (i >= 255)
direction = -5;
else if (i <= 0)
direction = 5;
if (color == 2)
color = 0;
color += 1;
i += direction;
Make timer a class member not just a local variable inside ProgramStarted. Doesn’t seem related to that particular exception, but still a right thing to do.
It shouldn’t but that’s a good practice. I’ll make that switch tonight.
No, even upping it the timer tick to 500, it still times out in roughly the same spot.
Also, I let the Hydra keep running over night and it eventually locked up as well, although I don’t know at what point. It was within 6 hours though, as I went to bed at 1am and went in the computer room around 7 to find it locked. Will see if moving the timer out of the program start makes a difference and report back.
I was printing out i on every tick, and it didn’t seem to matter whether debug.print was enabled or not, it still blew up around the same point - thought that may have had something to do with it, but doesn’t look like it.
I will add the GC status and see where that gets us.
Thanks for the suggestions - anything else you can think of, let me know. Think this would make a good intro project, so want it to work without blowing up
No, that’s a good point that I was I suppose driving to - I don’t know that the code is at fault, it could be something in the BETA release as well.
I figured by optimizing the code first, we could then narrow it down.
Will definitely see if that makes a different. I’ve got 4 Cerbs to try different variations on in addition to a Hydra and Spider, so hopefully we can figure it out.
GC: 133msec 5046348 bytes used, 1244784 bytes available
Type 0F (STRING ): 1464 bytes
Type 11 (CLASS ): 3081756 bytes
Type 12 (VALUETYPE ): 1500 bytes
Type 13 (SZARRAY ): 397428 bytes
Type 03 (U1 ): 156 bytes
Type 04 (CHAR ): 780 bytes
Type 07 (I4 ): 1044 bytes
Type 0F (STRING ): 60 bytes
Type 11 (CLASS ): 395304 bytes
Type 12 (VALUETYPE ): 84 bytes
Type 15 (FREEBLOCK ): 1244784 bytes
Type 17 (ASSEMBLY ): 30276 bytes
Type 18 (WEAKCLASS ): 96 bytes
Type 19 (REFLECTION ): 168 bytes
Type 1B (DELEGATE_HEAD ): 1151532 bytes
Type 1D (OBJECT_TO_EVENT ): 312 bytes
Type 1E (BINARY_BLOB_HEAD ): 373704 bytes
Type 1F (THREAD ): 1536 bytes
Type 20 (SUBTHREAD ): 144 bytes
Type 21 (STACK_FRAME ): 2052 bytes
Type 22 (TIMER_HEAD ): 144 bytes
Type 27 (FINALIZER_HEAD ): 120 bytes
Type 31 (IO_PORT ): 180 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 3864 bytes
GC: performing heap compaction...
1244784
GC: 135msec 5113668 bytes used, 1177464 bytes available
Type 11 (CLASS ): 3130716 bytes
Type 15 (FREEBLOCK ): 1177464 bytes
Type 1B (DELEGATE_HEAD ): 1169892 bytes
1177464
#### Exception System.OutOfMemoryException - CLR_E_OUT_OF_MEMORY (5) ####
#### Message:
#### System.Collections.Queue::Enqueue [IP: 0000] ####
#### Microsoft.SPOT.Dispatcher::BeginInvoke [IP: 001e] ####
#### Microsoft.SPOT.DispatcherTimer::Callback [IP: 0010] ####
Test code:
namespace TimerMemoryLeakTest
int i = 0;
int direction = 1;
timer.Start();
if (i >= 255)
direction = -1;
else if (i <= 0)
Debug.Print(Debug.GC(true).ToString());
direction = 1;
i += direction;
They say eyes believe that a LED is lit solid if it’s flashing on/off at 50hz.
If you’re just doing this for jollies and wanting to cycle up and down, then you should do the “double-down” rule and try 10 or 20 as a step-point, but I think you can safely assume that changing intensity in 1-step increments will not be noticeable to the eye and you need to think about this as potentially a larger step change, less often, depending on how fast you want the change to go from off to on and back again.
The actual code was using a counter of 5 or 10 to fade the color up to max intensity and then back down to zero before switching to the next. I switched it to 1 as the increment both for illustration purposes as well as to try and make it blow up “sooner” for debugging purposes.
So a combination of moving the GT.Timer declaration out of the ProgramStarted thread and upping the Timer’s tick milliseconds to 50+ seem to be the trick, at least on the Hydra. It does run longer, but still ends up blowing up with the GT.Timer declaration in ProgramStarted.
This combination ran all night long (and is actually still running at the house) and here is the new GC collect status:
GC: 2msec 433080 bytes used, 5858052 bytes available
Type 11 (CLASS ): 12552 bytes
Type 13 (SZARRAY ): 4260 bytes
Type 11 (CLASS ): 2136 bytes
Type 15 (FREEBLOCK ): 5858052 bytes
Type 1B (DELEGATE_HEAD ): 576 bytes
Type 1E (BINARY_BLOB_HEAD ): 373764 bytes
5858052
It’s been hovering here since the first or second GC, which went down, but then came back up after the ProgramStarted thread exited and got cleaned up by the GC.
I’m going to try it tonight on the Cerberus and see if it has similar performance.
I also realize the MultiColorLED can use the on-board processor to do the fade in and out on its own, but wanted to make sure for demo code to teach the basics of how to fade in/out a LED that doesn’t have an on-board chip, that the code was accurate.
Appreciate everyone’s input so far.
“Good” code:
int i = 0;
int direction = 1;
GT.Timer timer = new GT.Timer(50);
timer.Start();
if (i >= 255)
direction = -5;
else if (i <= 0)
direction = 5;
i += direction;
