I am not sure what version of the current but I have successfully updated the firmware and tried to program, finally no exceptions !!!
Thanks for your help, Aron.
Create TS.
Loading start at 806e0e8, end 809661c
Assembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0)Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)Assembly: Microsoft.SPOT.IO (4.2.0.0)
Assembly: System.IO (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)Assembly: Microsoft.SPOT.Net (4.2.0.0)
Assembly: System (4.2.0.0)Loading Deployment Assemblies.
Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.2.0)Attaching deployed file.
Assembly: GHI.OSHW.Native (4.2.2.0)Attaching deployed file.
Assembly: Cerb40_Exception_Test (1.0.0.0)Resolving.
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.2\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI OSHW NETMF v4.2 SDK\Assemblies\le\GHI.OSHW.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI OSHW NETMF v4.2 SDK\Assemblies\le\GHI.OSHW.Native.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘c:\my documents\visual studio 2010\Projects\Cerb40_Exception_Test\Cerb40_Exception_Test\bin\Debug\le\Cerb40_Exception_Test.exe’, Symbols loaded.
Hello World!
The thread ‘’ (0x1) has exited with code 0 (0x0).
Done.
Waiting for debug commands…
The program ‘[2] Micro Framework application: Managed’ has exited with code 0 (0x0).
