System.Net.Sockets
I was trying to get a webserver into my project.
But I have problems with using System.Net.Sockets;
Everytime It give a error.
Somebody know How I can put using System.Net.Sockets; into my progrem.
I also try to at the reference but could not find it
Can you post some of your code so we can see what you are trying to do?
What is the error you are getting?
Please post more info:
Hardware (Board, NW Module, …)
FW Version
Code
Here is my code.
The only error it gives is thet Sockets doesn’t excist in System.net
I use the Fez cobra and version 4.1
Program.cs
using Microsoft.SPOT.Input;
using Microsoft.SPOT.Touch;
using System.Net;
using System.Text;
using GHIGraphicalDemo.Presentation;
//using GHIElectronics.NETMF.FEZ;
namespace GHIGraphicalDemo
public class Program : Application
public static Program program;
Bitmap logo = Resources.GetBitmap(Resources.BitmapResources.ThomasMore_logo);
Configuration.StartUpLogo.Set(logo.GetBitmap(), (SystemMetrics.ScreenWidth - logo.Width ) / 2, (SystemMetrics.ScreenHeight - logo.Height) / 2);
        Program program = new Program();
        // Enable touch
        Touch.Initialize(program);
        TouchCollectorConfiguration.CollectionMethod = CollectionMethod.Native;
        TouchCollectorConfiguration.CollectionMode = CollectionMode.InkAndGesture;
        // Note, this is the amount of time (in ms) to elapse before sending a move event.
        TouchCollectorConfiguration.TouchMoveFrequency = 100; // 10 events a second times a second
        TestWindow currentWindow = new TestWindow(program);
        // Start the application.
        program.Run(currentWindow);
-------------------------------------------------------------------------------------------------------------------------And then the window with the code to read the sensor:
using System.IO.Ports;
using System.Text;
using System.Net;
using System.Text;
namespace GHIGraphicalDemo.Presentation
public class TestWindow : Window
    private Program _program;
    private string temper1 = "Temperatuur 1: ";
    private string temper2 = "Temperatuur 2: ";
    private byte[] adress = new byte[8];
    private ushort temperatuur;
    private static OneWire ow = new OneWire((Cpu.Pin)FEZ_Pin.Digital.IO21);
    private byte[] conT = new byte[1];
    private byte[] readrom = new byte[1];
    private byte[] rx = new byte[2];
    private Bitmap screen = new Bitmap(SystemMetrics.ScreenWidth, SystemMetrics.ScreenHeight);
    private Font ninaBFont = Resources.GetFont(Resources.FontResources.NinaB);
    private Font smallFont = Resources.GetFont(Resources.FontResources.small);
    private string[] lines = new string[12];
    public TestWindow(Program program)
        _program = program;
            ow.Reset();                   //temperatuur converteren
            ow.WriteByte(0xCC);
            ow.WriteByte(0x44);
            while (ow.ReadByte() == 0) ;
            ow.Reset();
            if (adress[0] == 0)
                ow.Search_GetNextDevice(adress);
            ow.Reset();
            ow.Search_IsDevicePresent(adress);
            ow.WriteByte(0xbe);
            temperatuur = ow.ReadByte();
            temperatuur |= (ushort)(ow.ReadByte() << 8);
            temper1 = ("Temperatuur 1 :" + temperatuur / 16 + " °C");
            ow.Reset();
            ow.WriteByte(0xbe);
            temper2 = ("Temperatuur 2 :" + temperatuur / 16 + " °C");
            DrawSettings();
    public override void OnRender(DrawingContext dc)
        dc.DrawImage(screen, 0, 0);
    private void DrawSettings()
        screen.Clear();
        screen.DrawText("Temperatuur in de kelder:", ninaBFont, Colors.Yellow, 8, 5);
        //Text
        //screen.DrawText(matchStr, ninaBFont, Colors.Yellow, 230, 65);
        screen.DrawText(temper1, ninaBFont, Colors.Red, 5, 100);
        screen.DrawText(temper2, ninaBFont, Colors.Red, 5, 150);
        screen.DrawText("Project pelletkachel KLIM & ELO", ninaBFont, Colors.White, 5, screen.Height - 15);
        screen.Flush();
1st: is there a reason you still use FW 4.1?
2nd:
which references have you added to your project.
Some of the namespaces are separated into multiple dll’s.
Some of them are called Microsoft.SPOT…
others only System…
In 4.2 ther are for example:
Microsoft.SPOT.Net
Microsoft.SPOT.Net.Security
and
System.Net.Security
Adding one of them to the references will give you the System.Net namespace, but not necessarily the System.Net.Socket class.
@ serneels - Add System.dll to the References
Thanks! I added the System.dll and the error went gone :slight_smile:
