I have a TCP server in a Raptor board, with MF 4.2, that has a problem: sometimes the Socket object appends a zero byte onto the end of a data message. About half the time I receive the correct size packet,and half the time I receive a packet with a zero appended at the end.
I am the using System.Net.Sockets.Socket class. I used WireShark to display the IP datagrams sent to the board, and the extra zero never appears in WireShark, even when it is received by the Socket.Receive function. Any help? Here is my entire socket server source code. After a incoming connection is established, m_clientSkt.Poll() function detects when data is available to be received, and m_clientSkt.Receive() gets the received byte array.
using System.Net;
using System.Net.Sockets;
using GHINET = GHI.Premium.Net;
using DeviceHive;
using Configuration;
using KioskUtility;
namespace SocketServer
public class TCPServerConstants
public const int BackLogCount = 4; //4; //max number of connections on the listening port
/// <summary>
/// TCP/IP Server
/// </summary>
private const int SERVER_PORT = 1000;
private Socket m_serverSkt;
private int m_port;
private Thread m_serverThread;
private GHINET.EthernetENC28J60 m_eth;
private AutoResetEvent m_CableConnectedEvent;
public bool m_srvRunning { get; set; }
// On Message Received event
public event ClientMsgRxDelegate OnMessageRx;
public Clienthandler[] m_handlerArray { get; set; }
private int m_MaxMessageSize;
private DeviceEngine m_ThisDevice;
public TCPServer(DeviceEngine dev)
: this(dev, SERVER_PORT, 0)
public TCPServer(DeviceEngine dev, int port)
: this(dev, port, 0)
public TCPServer(DeviceEngine dev, int port, int MaxMessageSize)
m_ThisDevice = dev;
m_port = port;
m_srvRunning = false;
m_serverSkt = new Socket(AddressFamily.InterNetwork,
SocketType.Stream, ProtocolType.Tcp);
m_handlerArray = new Clienthandler[TCPServerConstants.BackLogCount];
m_CableConnectedEvent = new AutoResetEvent(false);
m_MaxMessageSize = MaxMessageSize;
/// <summary>
/// Start the Server - listen for connections on a new thread
/// </summary>
/// <returns></returns>
public IPEndPoint Start( GHINET.EthernetENC28J60 _eth)
IPEndPoint svrEndPoint=null;
if (m_srvRunning)
// only allow one server thread at a time
Debug.Print("TCP Server not started - only one TCPServer instance allowed");
return null;
m_eth = _eth;
m_eth.CableConnectivityChanged += new GHINET.EthernetENC28J60.CableConnectivityChangedEventHandler(eth_CableConnectivityChanged);
m_srvRunning = true;
//Create local endpoint and bind to socket
svrEndPoint = new IPEndPoint(IPAddress.Any, m_port);
m_serverSkt.Bind(svrEndPoint);
m_serverSkt.Listen( TCPServerConstants.BackLogCount ); // limit number of connections
Debug.Print("Server Listening..");
//create and start our main server thread
m_serverThread = new Thread(ProcessServer);
m_serverThread.Start();
return svrEndPoint;
/// <summary>
/// /// Fire our message received event
/// </summary>
/// <param name="args"></param>
private void MessageRx(ClientEventArgs args)
if (OnMessageRx != null)
OnMessageRx(this, args);
/// <summary>
/// Count the number of TCP clients connected to this server
/// </summary>
private int GetCountConnectedClients()
int Count = 0;
Clienthandler handler;
for (int index = 0; index < TCPServerConstants.BackLogCount; index++)
handler = m_handlerArray[index];
if ( (handler != null) && (handler.m_clientConnected) )
Count++;
return Count;
/// <summary>
/// Find the first available Clienthandler slot in the m_handlerArray
/// </summary>
/// <param name="slot">Returns the index in the m_handlerArray that can be used for a new Clienthandler object</param>
/// <returns>true if an available slot was found</returns>
private bool GetFirstUnusedClientSlot(out int slot)
bool found=false;
slot = 0;
for ( int index=0; ((index < TCPServerConstants.BackLogCount) && (!found)); index++)
if (handler == null)
found = true;
slot = index;
else if (!handler.m_clientConnected)
found = true;
slot = index;
return found;
/// <summary>
/// This is our main server listening thread
/// </summary>
private void ProcessServer()
int slot;
while (m_srvRunning)
try
if (!m_eth.IsCableConnected)
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " SocketServer.ProcessServer( tcp port = " + m_port.ToString() + " ): Ethernet cable is not connected, waiting for connection");
m_CableConnectedEvent.WaitOne();
Thread.Sleep(3000);
// wait for a connection - will block
Socket client = m_serverSkt.Accept();
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " SocketServer.ProcessServer( tcp port = " + m_port.ToString() + " ): Connection to client");
// create a new session for the connection
if (GetFirstUnusedClientSlot(out slot))
Clienthandler handler = new Clienthandler(this, client);
m_handlerArray[slot] = handler;
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " Number of Clients: " + GetCountConnectedClients().ToString() + " Connected to TCP Port " + m_port.ToString());
Debug.Print(DateTime.Now.ToString("HH:mm:ss.fff") + " SocketServer.ProcessServer( tcp port = " + m_port.ToString() + " ): Closing client socket, no more connections allowed");
client.Close();
catch (SocketException ex)
KioskUtilities.LogException( "SocketServer.ProcessServer( tcp port = " + m_port.ToString() + " ): exception: ", ex);
catch (Exception ex)
KioskUtilities.LogException("SocketServer.ProcessServer( tcp port = " + m_port.ToString() + " ): exception: ", ex);
KioskUtilities.Reboot();
Debug.Print("SocketServer.ProcessServer( tcp port = " + m_port.ToString() + " ): exited server loop");
void eth_CableConnectivityChanged(object sender, GHINET.EthernetENC28J60.CableConnectivityEventArgs e)
try
if (e.IsConnected)
Debug.Print("TCPServer.CableConnectivityChanged Event - Ethernet cable is connected");
m_CableConnectedEvent.Set();
Debug.Print("TCPServer.CableConnectivityChanged Event - Ethernet cable is not connected");
KioskUtilities.LogException("TCPServer.eth_CableConnectivityChanged() exception ", ex);
#region client handler class
/// <summary>
/// Client socket handler helper class
/// </summary>
public class Clienthandler
public Socket m_clientSkt { get; set;}
public TCPServer m_serverSkt { get; set; }
private Thread m_clientThread;
private const int MICROSECS_SEC = 1000000;
private int m_readTimeout = 0;
public bool m_clientConnected { get; set; }
private byte[] m_MessageBuffer=null;
public Clienthandler(TCPServer server, Socket client)
m_serverSkt = server;
m_clientSkt = client;
m_readTimeout = 30 * MICROSECS_SEC;
m_clientConnected = true;
m_MaxMessageSize = server.m_MaxMessageSize;
if (m_MaxMessageSize > 0)
m_MessageBuffer = new byte[m_MaxMessageSize];
m_MessageBuffer = null;
ServiceClient();
public void ServiceClient()
// create and start our session thread
m_clientThread = new Thread(ProcessClient);
m_clientThread.Start();
/// <summary>
/// The session thread
/// Listen for messages
/// </summary>
private void ProcessClient()
try
using (m_clientSkt)
try
+ " Client connected from " + IPAddress.Parse(((IPEndPoint)m_clientSkt.RemoteEndPoint).Address.ToString())
+ " from port number " + ((IPEndPoint)m_clientSkt.RemoteEndPoint).Port.ToString()
+ " to port number " + m_serverSkt.m_port.ToString());
catch (Exception ex1)
Debug.Print(ex1.ToString());
try
if (m_clientSkt.Poll(m_readTimeout, SelectMode.SelectRead))
// if read buffer is 0, then no data after timeout means socket may be gone
int bytesavail = m_clientSkt.Available;
if (bytesavail <= 0)
{ // exit thread, close socket
+ " bytesavail = " + bytesavail.ToString()
+ " Client lost, close connection on port " + m_serverSkt.m_port.ToString());
m_clientConnected = false;
break;
// we have a message
byte[] buffer;
if ((m_MaxMessageSize > 0) && (m_MessageBuffer != null) && (bytesavail < m_MaxMessageSize))
buffer = m_MessageBuffer;
buffer = new byte[bytesavail];
int bytesRead = m_clientSkt.Receive(buffer, bytesavail, SocketFlags.None);
if (bytesRead <= 0)
+ " bytesRead = " + bytesRead.ToString()
break;
ClientEventArgs args = new ClientEventArgs(m_clientSkt.LocalEndPoint, buffer, bytesRead);
//ClientEventArgs args = new ClientEventArgs(m_clientSkt.LocalEndPoint, buffer, bytesavail);
// let server notify of message
m_serverSkt.MessageRx(args);
// check if a response is returned in args
if (args.Response != null)
// send back the response
m_clientSkt.Send(args.Response);
Debug.Print("Client exception on tcp port " + m_serverSkt.m_port.ToString() + " Exception: " + ex.ToString());
break;
} //while (true)
} //using (m_clientSkt)
Debug.Print("# Clients: " + m_serverSkt.GetCountConnectedClients().ToString() + " Connected to TCP Port " + m_serverSkt.m_port.ToString());
} //private class Clienthandler
#endregion
} //public class Server
/// <summary>
/// Event args for client messages received
/// </summary>
public class ClientEventArgs:EventArgs
public IPEndPoint ClientEndPoint { get; private set; }
public byte[] Message { get; private set; }
public int Size { get; private set; }
public byte[] Response { get; set; }
public ClientEventArgs(EndPoint _clientEP, byte[] _message, int _size)
ClientEndPoint = (IPEndPoint)_clientEP;
//if (message == null) return;
//Message = new byte[message.Length];
//message.CopyTo(Message,0);
Message = _message;
Size = _size;
public delegate void ClientMsgRxDelegate(object sender,ClientEventArgs e);
} //namespace SocketServer
using System.Text;
namespace TCPServer
public partial class Program
private Server m_tcpServer;
private int count = 1;
string ipAddress = ethernetForMountaineerEth.NetworkSettings.IPAddress;
int port = 1000;
m_tcpServer = new Server(port);
m_tcpServer.OnMessageRx += new ClientMsgRxDelegate(m_tcpServer_OnMessageRx);
try
m_tcpServer.Start();
Debug.Print("Server running :" + ipAddress + ":" + port);
catch (Exception)
Debug.Print("Error starting server, is ethernet connected?");
void m_tcpServer_OnMessageRx(object sender, ClientEventArgs e)
// note this is not called on main thread
// convert byte[] to string
string message = new string(Encoding.UTF8.GetChars(e.Message));
Debug.Print("Rx Msg " + count + ":" + message);
Debug.Print("Client :" + e.ClientEndPoint.Address + ":" + e.ClientEndPoint.Port);
// generate a response to send back to the client
e.Response = Encoding.UTF8.GetBytes(" Message " + count++ +" Received");
