I have a Fez Spider with .net micro Framework 4.1 and GHI NETMF v4.1 installed in my computer. I have added using System namespace to my code.
But I cant see the System.Convert class.
What I need to do is;
convert integer to byte
example bytes[0] = Convert.ToByte(23); which is 0x17 as in .Net Framework
The System.Convert functions in NETMF only converts strings.
int x = 1;
//not sure why you would want to do this
System.Convert.ToByte(x.ToString());
//when you can directly cast the integer to a byte
byte b = (byte)x;
