I have a Terminal block breakout module and I am having some trouble setting up which ports on the terminal blocks.
Every time I try it throws a “System.ArgumentException” around this line of code.
If the project that you are making requires pull-down resistors, you could add an external resistor to the pin that requires it and set the resistor mode to none.
