If I have two or more FEZs, each FEZ connects with accelerometer.
I want these FEZs synchronize sensing. How could I do this?
And the Timer seems not accurate for sensing. For example, if my sampling rate is 200HZ (sampling one data per 5ms), If I set the timer to 5ms to get the data. The time span seems not exact the 5ms. Synchronizing and accurate sampling is very important for my project.
Thank you very much
You don’t say how you are pulling data from the accelerometer. Is it an analog output, SPI, etc? If each sample is timestamped does it matter that they are not synchronized?
