I’ve found ferrules used with screw terminal blocks to be a more mechanically stable way to connect gadgeteer sockets on a vibrating platform than breadboard pins and sockets.
And the gadgeteer lives on
That looks suspiciously like a hexabot.
Gadgeteer forever ! ![]()
Yes agree, we always use Ferrules on all cables that go into screw down terminals. Its amazing after you do that how much abuse cable ends can handle out int he field.
Correct tool the job and all that!!
I also use ferrules for all connections, even for hole projects these days too. Money and time well spent.
Also, having the correct tool to make up crimp pins is worth the cost too. For years I used a cheap Chinese made crimp tool for the Molex KK connections. It worked but was fiddly to make up but the cable would occasional pull out if pull the connector off by the cables. Since I switched to using a proper expensive (around US$500) Molex branded tool, pulling on the cables would pull the crimp out of the socket rather than leave it in there. It would of course be damaged by this but it did prove that the correct tool is worth the purchase price. I use these connectors for everything where I need a board level connection that doesn’t need the use of a screw terminal.
Ah, I got to build one of those one day.
Wow…, is this thing under US military non diclosure restriction or is it documented somewhere as an open source project?
Okay, the thing is way over-engineered. It’s a retirement project, and I absolutely don’t know what I’m doing. The structure (minus the servos) came from a kit. The controller and payload are symptomatic of my own peculiar requirements. Right now I’m dealing with the device drivers. The interesting software comes later.
Looks great, …happy coding. Let us see it move when you made some progress.
