Has anyone else observed that StreamReader.Peek() and .Read() seem to have a broken interaction with each other? In writing a parser, I noticed that if I use .Peek() to test a character and then .Read() to ‘eat’ that character if it is in the desired character set, the .Read will skip ahead one character in the stream if the .Peek() occured at an internal buffer boundary. For example, this code will drop one character if the token read occurs at a 512-byte boundary in the source stream:
StringBuilder sbToken = new StringBuilder();
do
sbToken.Append(ch);
if (IsValidTokenChar((char)sourceReader.Peek()))
ch = (char)sourceReader.Read();
break;
} while (true);
The StreamReader above is reading across a memory stream that was derived from a string. The buffer appears to contain the right data given the contents of the original string.
