I’ve encountered a strange problem whilst using a socket class to receive data over a network.
I am using a Fez Cobra II with a built in Wifi RS9110 module and I’m using the following code to listen for incoming messages:
Debug.Print("Listening on port " + _listeningPort.ToString());
while (_isListening)
if (socket.Poll(-1, SelectMode.SelectRead))
Socket receive = socket.Accept();
if (receive.Available > 0)
byte[] buffer = new byte[receive.Available];
receive.Receive(buffer);
ProcessStream(new String(Encoding.UTF8.GetChars(buffer)));
Whilst testing the code I noticed that some messages that I broadcast from the server were being ignored. I tested the situation by adding a debug line that I could stock a break point on:
Debug.Print("Report Available=0");
When is stopped on the breakpoint I looked at the value of receive.Available and it was not zero. I suspected that it might be a timing issue as sometimes it would work and sometimes it wouldn’t, so I decided to put a slight delay in just in case there was another thread at work:
Thread.Sleep(100);
This seemed to solve the problem and data stopped getting lost. However, I’m not particularly happy with this solution as I don’t understand what is happening and I’m not convinced that it will work in all cases.
Can anyone shed any light on this?
Is there a more reliable way of doing it, or possible a better work-around?
