Strange problem on EMX module GPIO
I’m using an emx do develop my application in the first part of the code I have a problem, I can setup all pin as GPIO except for the IO75.
What’s the reason??
Tks
            Stato = 0;
            HoldOn = new OutputPort(EMX.Pin.IO15, true);
            HoldOn.Write(true);
            oPompa = new OutputPort(EMX.Pin.IO9, false);
            oValvola = new OutputPort(EMX.Pin.IO16, false);
            oLedPompa = new OutputPort(EMX.Pin.IO30, false);
            oLedAria = new OutputPort(EMX.Pin.IO23, false);
            iPompa = new InputPort(EMX.Pin.IO75, true, Port.ResistorMode.PullUp);
            iBattLow = new InputPort(EMX.Pin.IO22, true, Port.ResistorMode.PullUp);
            iNoAC = new InputPort(EMX.Pin.IO20, true, Port.ResistorMode.PullUp);
what happens?
Exception System.ArgumentException - 0xfd000000 (1)
#### Message:
#### Microsoft.SPOT.Hardware.Port::.ctor [IP: 0000] ####
#### Microsoft.SPOT.Hardware.InputPort::.ctor [IP: 0008] ####
#### MB16AW.Program::Main [IP: 0041] ####
Eccezione first-chance di tipo ‘System.ArgumentException’ in Microsoft.SPOT.Hardware.dll
Eccezione non gestita di tipo ‘System.ArgumentException’ in Microsoft.SPOT.Hardware.dll
Only interrupts pins can use glitch filter. Try it with false.
