Hi all,
today I face the strange behaviour of my FEZ Raptor. After uploading the application from VS2012 the debugger was quite a long time “silent” and seems not working and after this there is following in the Output window. It seems that garbage collector is trying something but without success. I have try to reset/unplug/plug again and the behaviour is the same.
Day ago I have uploaded this application a lot of time without this issue and now I have this problem. I am little bit disappointed by this behaviour because it seems there is quite often some new and new and new  behaviour…
I am writing an application which should be of course as stable as possible because it will be used commercially for monitoring of some technology(GSM connection through RS232, another two RS232 communication, Ethernet monitoring(not yet implemented)) so I am afraid I am able to do this - but actually I do not have any other solution as HW and everything else is almost ready. So I hope I will be able to make stable application for my customer…
Thank for help.
Output from VS Output window
Found debugger!
Create TS.
Loading start at 202d8818, end 20307cac
Assembly: mscorlib (4.3.1.0)     Assembly: Microsoft.SPOT.Native (4.3.1.0)     Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0)     Assembly: System.Security (4.3.1.0)     Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0)     Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0)     Assembly: System.IO (4.3.1.0)     Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0)     Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0)     Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.6.0) Attaching deployed file.
Assembly: System (4.3.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZRaptor (4.3.6.0) Attaching deployed file.
Assembly: MTC2 (1.0.0.0) Attaching deployed file.
Assembly: GHI.Usb (4.3.6.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Resolving.
GC: 1msec 344568 bytes used, 66761196 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 66761196 bytes
Type 17 (ASSEMBLY ): 36288 bytes
Type 1E (BINARY_BLOB_HEAD ): 308184 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Usb.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZRaptor\NETMF 4.3\le\GHIElectronics.Gadgeteer.FEZRaptor.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘d:\Projects\Monti\MTC2\MTC2\bin\Debug\le\MTC2.exe’, Symbols loaded.
GC: 2762msec 67051020 bytes used, 54744 bytes available
Type 0F (STRING              ):   1128 bytes
Type 11 (CLASS               ):  12648 bytes
Type 12 (VALUETYPE           ):   1128 bytes
Type 13 (SZARRAY             ):   5808 bytes
Type 03 (U1                  ):   1164 bytes
Type 04 (CHAR                ):   1032 bytes
Type 07 (I4                  ):   1332 bytes
Type 0F (STRING              ):    216 bytes
Type 11 (CLASS               ):   2064 bytes
Type 15 (FREEBLOCK           ):  54744 bytes
Type 16 (CACHEDBLOCK         ):    264 bytes
Type 18 (WEAKCLASS           ):     48 bytes
Type 19 (REFLECTION          ):    168 bytes
Type 1B (DELEGATE_HEAD       ):    540 bytes
Type 1D (OBJECT_TO_EVENT     ):    240 bytes
Type 1E (BINARY_BLOB_HEAD    ): 323508 bytes
Type 1F (THREAD              ):   1920 bytes
Type 20 (SUBTHREAD           ):    240 bytes
Type 21 (STACK_FRAME         ): 66662328 bytes
Type 27 (FINALIZER_HEAD      ):    216 bytes
Type 31 (IO_PORT             ):    180 bytes
Type 33 (I2C_XACTION         ):     48 bytes
Type 36 (APPDOMAIN_ASSEMBLY  ):   4248 bytes
GC: 2763msec 67082124 bytes used, 23640 bytes available
Type 0F (STRING              ):   1176 bytes
Type 13 (SZARRAY             ):   5844 bytes
Type 03 (U1                  ):   1200 bytes
Type 15 (FREEBLOCK           ):  23640 bytes
Type 21 (STACK_FRAME         ): 66693564 bytes
Type 26 (WAIT_FOR_OBJECT_HEAD):     48 bytes
Failed allocation for 17 blocks, 204 bytes
GC: 2770msec 67082316 bytes used, 23448 bytes available
Type 11 (CLASS               ):  12708 bytes
Type 15 (FREEBLOCK           ):  23448 bytes
Type 1E (BINARY_BLOB_HEAD    ): 323688 bytes
Failed allocation for 39 blocks, 468 bytes
