Firmware: 2.1.0.6400
Code:
using GHIElectronics.TinyCLR.Devices.Spi;
using GHIElectronics.TinyCLR.Drivers.BasicGraphics;
using GHIElectronics.TinyCLR.Drivers.Infrared;
using GHIElectronics.TinyCLR.Drivers.Sitronix.ST7735;
using System.Collections;
using System.Diagnostics;
using System.Text;
namespace IRSample
internal class Program
static void Main()
bool power = false;
//connect the IR receiver to PIN 1 of the FEZBit
var receivePin = GpioController.GetDefault().OpenPin(FEZBit.GpioPin.P1);
var ir = new NecIRDecoder(receivePin);
//Display the power status using the onboard LED
GpioPin led = GpioController.GetDefault().OpenPin(FEZBit.GpioPin.Led);
led.SetDriveMode(GpioPinDriveMode.Output);
//Init the display controller
ST7735Controller st7735 = null;
BasicGraphics basicGfx = new BasicGraphics(160, 128, ColorFormat.Rgb565);
uint colorBlue = BasicGraphics.ColorFromRgb(0, 0, 255);
// Display Get Ready ////////////////////////////////////
var spi = SpiController.FromName(FEZBit.SpiBus.Display);
var gpio = GpioController.GetDefault();
st7735 = new ST7735Controller(
spi.GetDevice(ST7735Controller.GetConnectionSettings
(SpiChipSelectType.Gpio,
gpio.OpenPin(FEZBit.GpioPin.DisplayChipselect))), //CS pin.
gpio.OpenPin(FEZBit.GpioPin.DisplayRs), //RS pin.
gpio.OpenPin(FEZBit.GpioPin.DisplayReset) //RESET pin.
var backlight = gpio.OpenPin(FEZBit.GpioPin.Backlight);
backlight.SetDriveMode(GpioPinDriveMode.Output);
backlight.Write(GpioPinValue.High);
st7735.SetDataAccessControl(true, true, false, false); //Rotate the screen.
st7735.SetDrawWindow(0, 0, 160, 128);
st7735.Enable();
UpdateIndicators(power, basicGfx, colorBlue, st7735, led);
ir.OnDataReceivedEvent += (address, command) =>
Debug.WriteLine("A: " + address + " C: " + command);
power = !power;
ir.OnRepeatEvent += () =>
Debug.WriteLine("Repeat!");
public static void UpdateIndicators(bool pwr, BasicGraphics bGfx, uint color, ST7735Controller screen, GpioPin led)
bGfx.Clear();
bGfx.DrawString("Power: " + (pwr ? "ON" : "OFF"), color, 10, 40, 2, 2);
try
screen.DrawBuffer(bGfx.Buffer); //Exception occurs on this call
led.Write(pwr ? GpioPinValue.High : GpioPinValue.Low);
catch (Exception ex)
Debug.WriteLine(ex.Message);
Output Window:
Found debugger!
Create TS.
Attaching deployed file.
Assembly: mscorlib (2.1.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Devices.Spi (2.1.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Native (2.1.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Devices.Gpio (2.1.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Drivers.BasicGraphics (2.1.1.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Drivers.Sitronix.ST7735 (2.1.0.0) Attaching deployed file.
Assembly: IRSample (1.0.0.0) Attaching deployed file.
Assembly: GHIElectronics.TinyCLR.Drivers.Infrared (2.1.0.0) Resolving.
Ready.
‘GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.dll’ (Managed): Loaded ‘C:\Users\crazy\OneDrive\Development\TinyCLR\Blinky\IRSample\bin\Debug\pe…\GHIElectronics.TinyCLR.Native.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.dll’ (Managed): Loaded ‘C:\Users\crazy\OneDrive\Development\TinyCLR\Blinky\IRSample\bin\Debug\pe…\GHIElectronics.TinyCLR.Devices.Gpio.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.dll’ (Managed): Loaded ‘C:\Users\crazy\OneDrive\Development\TinyCLR\Blinky\IRSample\bin\Debug\pe…\GHIElectronics.TinyCLR.Devices.Spi.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.dll’ (Managed): Loaded ‘C:\Users\crazy\OneDrive\Development\TinyCLR\Blinky\IRSample\bin\Debug\pe…\GHIElectronics.TinyCLR.Drivers.BasicGraphics.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.dll’ (Managed): Loaded ‘C:\Users\crazy\OneDrive\Development\TinyCLR\Blinky\IRSample\bin\Debug\pe…\GHIElectronics.TinyCLR.Drivers.Sitronix.ST7735.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.dll’ (Managed): Loaded ‘C:\Users\crazy\OneDrive\Development\TinyCLR\Blinky\IRSample\bin\Debug\pe…\GHIElectronics.TinyCLR.Drivers.Infrared.dll’, Skipped loading symbols. Module is optimized and the debugger option ‘Just My Code’ is enabled.
‘GHIElectronics.TinyCLR.VisualStudio.ProjectSystem.dll’ (Managed): Loaded ‘C:\Users\crazy\OneDrive\Development\TinyCLR\Blinky\IRSample\bin\Debug\pe…\IRSample.exe’, Symbols loaded.
Step into: Stepping over non-user code ‘IRSample.Program.’
A: 0 C: 0
Repeat!
A: 0 C: 0
A: 0 C: 0
A: 0 C: 0
Repeat!
A: 0 C: 0
Repeat!
A: 0 C: 0
A: 0 C: 0
Repeat!
A: 0 C: 0
A: 0 C: 0
#### Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (3) ####
#### Message:
#### GHIElectronics.TinyCLR.Devices.Spi.Provider.SpiControllerApiWrapper::WriteRead [IP: 0000] ####
#### GHIElectronics.TinyCLR.Devices.Spi.SpiDevice::WriteRead [IP: 001d] ####
#### GHIElectronics.TinyCLR.Devices.Spi.SpiDevice::Write [IP: 000b] ####
#### GHIElectronics.TinyCLR.Devices.Spi.SpiDevice::Write [IP: 0009] ####
#### GHIElectronics.TinyCLR.Drivers.Sitronix.ST7735.ST7735Controller::DrawBuffer [IP: 0019] ####
#### IRSample.Program+<>c__DisplayClass0_0::b__0 [IP: 003a] ####
#### GHIElectronics.TinyCLR.Drivers.Infrared.NecIRDecoder::Rx_ValueChanged [IP: 017d] ####
#### GHIElectronics.TinyCLR.Devices.Gpio.GpioPin::OnValueChanged [IP: 000e] ####
#### GHIElectronics.TinyCLR.Devices.Gpio.Provider.GpioControllerApiWrapper::OnDispatcher [IP: 0047] ####
Exception thrown: ‘System.InvalidOperationException’ in GHIElectronics.TinyCLR.Devices.Spi.dll
Exception was thrown: System.InvalidOperationException
Repeat!
The program ‘[6] TinyCLR application: Managed’ has exited with code 0 (0x0).
