This is the session:
M S>10
!00
M B
!00
M C
!00
M C
!00
M C
!00
M C
!00
M C
!00
M C
!00
M C
!00
M E
!00
$0000DB2E
!00
The file is saved on the SD card with 6kb but I cannot play it. Any hints?
M S>10
!00
M B
!00
M C
!00
M C
!00
M C
!00
M C
!00
M C
!00
M C
!00
M C
!00
M E
!00
$0000DB2E
!00
Does your player support mjpeg? Which player? Have you tried a different player?
@ njbuch -
0x0000DB2E = 56K, not 6K. check your SD. Try to format or different SD!
Card problem. Works now.
Is it possible to press the button on the module for each stop instead of sending capture command?
Yes. Check on FAQ Gus posted.
Just is, you can not use both command and button in one movie. If start recording by the button, use the button all the time. If start by sending commands, use command, please.
Hmm, my english is not good enough to understand how to use stop-motion with button alone:
[quote]Q: How do I record a movie by using the button?
A: There are 3 kind of recording ALCAM supports.
Is it:
@ njbuch -
@ Dat - Great, but how to set ind stopmotion mode with the button? (I feel stupid!) :think:
Lets assume I want to do stopmotion, and nothing else, what to do?
@ njbuch -
You have to load the config file.
If VBAT is connected, all these config are saved for next reset, even disconnect power source.
If no VBAT, but don’t disconnect power source, these value is still saved after reset.
Press and hold the button from 3-9 seconds same as “M B” command, and “M B” command does not do any thing with movie mode, just start recording.
aha! The conf file was the missing link. So it’s not possible with the button.
Will investigate.
@ njbuch -
yeb, with the config file, you can change any configuration in ALCAM, movie mode is just one of them.
