dobova
December 6, 2018, 3:42pm
#1
Hi @Dat_Tran , I’m not able to let run my F746 devices with TinyCLR since first 1.0.0.0 preview (1,2 & 3)
I found that in the main.cpp the call:
TARGET(_Startup_GetRunApp)(runApp);
TinyCLR_Startup_Start(&OnSoftReset, runApp);
It seems that call to TinyCLR_Startup_Start() fail or exit as soon called, so the device just lockup returning from main.
Is it a problem in the lib for cortex-m7? Other device (769/767) are working fine.
I double checked .ldf file but with no luck…
dobova
December 6, 2018, 6:42pm
#3
Here it is… This works fine with TinyCLR V0.12.0
ENTRY(EntryPoint)
MEMORY
IRAM (rw) : ORIGIN = 0x20000000, LENGTH = 0x50000 /* end: 0x2004FFFF */
LR_FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024k
SDRAM (rwx) : ORIGIN = 0x60000000, LENGTH = 16m /* 0x800000 */
SECTIONS
ER_FLASH 0x08000000 :
* (i.EntryPoint)
* (SectionForBootstrapOperations)
* (SectionForFlashOperations)
* (.text*)
* (i.*)
* (.rodata*)
* (rodata)
* (.constdata*)
* (.conststring*)
* (.glue*)
* (tinyclr_metadata)
* (SectionForCode*)
PROVIDE(_sbrk = .);
PROVIDE(_write = .);
PROVIDE(_close = .);
PROVIDE(_fstat = .);
PROVIDE(_lseek = .);
PROVIDE(_read = .);
PROVIDE(_exit = .);
PROVIDE(_getpid = .);
PROVIDE(_kill = .);
PROVIDE(abort = .);
PROVIDE(__errno = .);
PROVIDE(_read = .);
PROVIDE(isatty = .);
PROVIDE(_isatty = .);
}>LR_FLASH
ER_VECTORS 0x20000000 :
* (VectorTable)
}>IRAM
ER_RAM_RW 0x20000200 : ALIGN(0x08)
* (rwdata)
* (.data*)
}>IRAM AT>LR_FLASH
.bss (NOLOAD) : ALIGN(0x08)
* (.bss*)
* (.zidata*)
PROVIDE(__exidx_start = .);
PROVIDE(__exidx_end = .);
* (COMMON)
}>IRAM
ER_RAM_RO : ALIGN(0x08)
}>IRAM AT>LR_FLASH
/DISCARD/ :
* (.ARM.exidx*)
* (.ARM.extab*)
/************************NORMAL HEAP ALLOCATION in MCU SRAM***************************
ER_HEAP_BEGIN 0x20009000 :
* (SectionForHeapBegin)
}>IRAM
ER_HEAP_END 0x2004A000 - 0x08 :
* (SectionForHeapEnd)
}>IRAM
/***********************External SDRAM Allocation ***********************************/
ER_HEAP_BEGIN 0x60000000 :
}>SDRAM
ER_HEAP_END 0x60800000 - 0x08 :
}>SDRAM
ER_RLP_BEGIN 0x2004A000 :
* (SectionForRlpBegin)
}>IRAM
ER_RLP_END 0x2004C000 - 0x08 :
* (SectionForRlpEnd)
}>IRAM
/* STACK POINTER */
ER_STACK_BOTTOM 0x2004C000 :
* (SectionForStackBottom)
}>IRAM
ER_STACK_TOP 0x20050000 - 0x08 :
* (SectionForStackTop +LAST)
}>IRAM
Load$$ER_FLASH$$Base = LOADADDR(ER_FLASH);
Image$$ER_FLASH$$Length = SIZEOF(ER_FLASH);
Image$$ER_RAM_RO$$Base = ADDR(ER_RAM_RO);
Image$$ER_RAM_RO$$Length = SIZEOF(ER_RAM_RO);
Load$$ER_RAM_RO$$Base = LOADADDR(ER_RAM_RO);
Image$$ER_RAM_RW$$Base = ADDR(ER_RAM_RW);
Image$$ER_RAM_RW$$Length = SIZEOF(ER_RAM_RW);
Load$$ER_RAM_RW$$Base = LOADADDR(ER_RAM_RW);
Image$$ER_RAM_RW$$ZI$$Base = ADDR(.bss);
Image$$ER_RAM_RW$$ZI$$Length = SIZEOF(.bss);
Load$$ER_RLP$$Base = LOADADDR(ER_RLP_BEGIN);
Image$$ER_RLP$$Length = LOADADDR(ER_RLP_END) - LOADADDR(ER_RLP_BEGIN);
__use_no_semihosting_swi = 0;
Can you try to switch heap into internal SRAM to see what happen?
dobova
December 7, 2018, 9:14am
#5
@Dat_Tran thank you. I’ve tested both memory type (internal SRAM or ext SDRAM) but no difference. Same problem.
After some more tests I found that
is called and lockup inside the function, but OnSoftReset() is never called.
And what latest version that worked on that devices? I can check if any different, is it Prew0.12.0?
dobova
December 7, 2018, 1:08pm
#7
Yes on 0.12.0 it works fine. I’ve flashed again 0.12 firmware and it works fine both with sram and with sdram, hs and fs usb
EDIT: I’m going to think that there’s something not correct for F746 in the STM32F7_Deployment…
