Is there a stepper motor out there with a hollow shaft? If not, then what do you suppose is the practicality of building a stepper motor?
The closest that I have seen is a linear stepper motor. It’s “shaft” is just a nut that rotates. This moves a thredded rod.
I have never seen a normal stepper with a hollow shaft.
Building a stepper with more than 10 steps per revolution will be tough…
Maybe you can open a motor and replace the shaft, although that will be tough as the shaft is pressed in or worse…
What about running a gear with the motor to the side of a hollow shaft with another gear
There will be some added backlash i guess…
Yea, backlash is a problem there. Ah well.
Ahem … Tadaaa one 66mm hollow shaft stepper
I am sure here is what you want
RobotDigg
nice post - welcome.
Not practical, because the shaft can break easier.
EDIT: Let me clarify, not for large motors because the shaft can break/bend easier.
You can’t open the motor without special equipment, because if you touch the magnet to any metal part, the magnet will be demagnetized to 1/3 of it’s original strength. Steppers are magnetized after they are built.
