Anyone have example code or am I not finding something that’s already out there? It seems there are a lot of parameters to set up and reading through the driver source has left me in no better position.
Thanks if you can help!
Here is a snippet of sample code. The parameters to the registers are set with default settings. If you require specific settings, the value of the registers will depend on the motor itself.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace Stepper_L6470_Example
public partial class Program
const uint MAX_MOTOR_SPEED = 100000;
const uint MOTOR_SPEED_INCREMENT = 1000;
uint MOTOR_SPEED = 0;
bool MOTOR_MOVING = false;
/// <summary>
/// Move the motor to a specific position
/// </summary>
/// <param name="location">How many steps to move</param>
void GoTo(uint location)
stepper_L6470.GoToPosition(location);
/// <summary>
/// Set the motor to the specified speed
/// </summary>
/// <param name="speed"></param>
void SetSpeed(uint speed)
MOTOR_SPEED = speed;
if (MOTOR_SPEED > MAX_MOTOR_SPEED)
MOTOR_SPEED = MAX_MOTOR_SPEED;
if (MOTOR_MOVING)
stepper_L6470.HardStop();
stepper_L6470.Run(GTM.GHIElectronics.Stepper_L6470.Direction.FWD, MOTOR_SPEED);
void GetStatus()
ushort mask = 0x01;
ushort status = stepper_L6470.GetStatus();
if ((status & mask) == 0x01)
Debug.Print("HiZ Detected");
//Shift to next register
status = (ushort)(status >> 1);
Debug.Print("Device is busy");
Debug.Print("SW_F Detected");
Debug.Print("SW_ENV Detected");
Debug.Print("DIR: True");
Debug.Print("MOT_STATUS_1 Detected");
Debug.Print("MOT_STATUS_2");
Debug.Print("NOTPERF_CMD");
Debug.Print("Wrong Command Detected");
Debug.Print("UVLO");
Debug.Print("THERMAL WARNING");
Debug.Print("TH_SD");
Debug.Print("Over-current detection");
Debug.Print("STEP_LOSS_A");
Debug.Print("STEP_LOSS_B");
Debug.Print("SCK_MOD");
