I need to use https to access some data from a webserver.
I have seeded SSL from MFdeploy, and it works ok.
I am selling controllers based on G120. It is important that these controllers do not stop working in the future.
My question is: Will this continue to work or do I get some Certificate problems later?
The only known problem is a small memory leak in SSL. With megabytes of available ram on G120, you may not run out of memory for a while, depending on your application. The easy fix is to automatically reset the device periodically. This maybe needed once a week for example.
NETMF only supports TLS 1.0 encryption. You might get problems if the server only accepts e.g. TLS 1.2. We’re looking forward to see TLS 1.2 on TinyCLR.
Regards
RoSchmi
I am asking for 1.3
