Looking to store your application data in a SQL database ? SQLlite is one way to do that.
Requires the Microsoft.Data.Sqllite Nuget.
using Microsoft.Data.Sqlite;
var id = 1;
var dataFile = "sqltest.db";
//Create a new database file
using (var connection = new SqliteConnection($"Data Source={dataFile}"))
connection.Open();
var command = connection.CreateCommand();
//Create a new table
command.CommandText = "CREATE TABLE IF NOT EXISTS user (id INTEGER PRIMARY KEY, name TEXT)";
command.ExecuteNonQuery();
//Insert a new row
command.CommandText = "INSERT INTO user (name) VALUES ('World 1')";
//query the database
command.CommandText = @"SELECT name FROM user WHERE id = $id";
command.Parameters.AddWithValue("$id", id);
//print the result
using (var reader = command.ExecuteReader())
while (reader.Read())
var name = reader.GetString(0);
Console.WriteLine($"Hello, {name}!");
//delete the data file when done
FileInfo dbFile = new FileInfo(dataFile);
try
if (dbFile.Exists)
dbFile.Delete();
catch(Exception ex)
Console.WriteLine("Unable to delete the data file"+ex.Message);
