Hello!
I am wondering if it makes any sense and/or is there a good way to
use general purpose i/o’s for multi-use within a application.
For example, I need a lot of dio’s and also need a lot of spi chip select.
I know I cannot do the following (tried it but get an exception):
GT.Socket socket = GT.Socket.GetSocket(6, false, null, null);
m_pin = socket.CpuPins[3]; // note - trying to use the same pin for 2 different things.
m_SPI_Cfg = new SPI.Configuration(
m_pin, // chip select
false, // set low when accessing the chip
0,
0,
true, // clock signal will be set to high while the device is idle
true, // data is sampled on the SPI clock falling edge
1000,
SPI.SPI_module.SPI2);
m_dio[0] = new OutputPort(m_pin, false); //get exception here
now, wondering would it make sense to configure for spi as shown above, then
whenever I want to use it as an i/o and not spi, just turn on or off the i/o by reconfiguring?
ie -
m_pin,
false,
later in the application, need to turn on the i/o so -> reconfig
m_SPI_Cfg=newSPI.Configuration(
m_pin,
true,
I’m sure this seems a little crazy, however, I will need 20 di/o’s and 20 spi channels and
will not be able to do this (40 i/o’s not avail on spider) unless I get creative…
Also, might look at multiplexing with 3 i/o’s for spi to get 24 channels, but not sure yet.
So, does anyone have an idea and do you see a problem with reconfiguring the spi channel everytime I need to turn on or off a dig. i/o?
thanks!
David
