Hello,
I’m creating a project on SPIDER & DisplayT35…
I have a WPF Screens + icons + Button events Status & Timer event displaying date & Time…
My need : How do we realise the displayMode Management ??
I tried :
My_WPF_Window.Visibility = Visibility.Visible;
My_WPF_Window.Visibility = Visibility.Hidden;
My_WPF_Window.Visibility = Visibility.Collapsed;
But it doesn’t work & I don’t know why …
I would like to realise the same Screen management than the one which is running perfectly on my Panda II
Thanks for your reply, I’m an obvious noob. In a professional sense I write vb.NET stuff, pretty UI’s, lots of data analysis, C# is new to me but fairly easy to pickup, the entire concept of hardware manipulation is something I’m trying to learn on my own from scratch (well, with generous help from this community and others).
I’m learning a lot about code efficiency and realizing the difficulties of even simple designs, for instance, my Temp&Humidity Module is about 2 degrees off because of the heat coming off the USB power module.
Anyway, thank you for your time, I really appreciate it
