Hi I have purchased a Fez Spider and the display will only show a solid white screen when power is applied. The conections have been checked and double checked and this is all that ever happens. There has never been any messaged displayed on startup. A powered USB hub has been used to ensure enough power. Firmware updates have been applied.
The kit was purchased through Australian Robotics.
I have gone through the getting started tutorial for the camera project. I originally had issues with the button module not working, so I performed the firmware upgrade. The buttons are now working along with the led components. It was not until I was trying to take a picture and view on the display that I have noticed the issue.
I originally ran the spider from only the pc, but when this was not working I saw on the forums to try a powered USB hub. I have the same results either way.
Gus, I have added the display through the designer. The designer adds the connections in the program.generated.cs. I have recreated the project several times an always get the same result. I have tried the reset button but it appears not to make any difference. No text is ever displayed on boot.
We are adding a wiki page to troubleshoot the display. Till then, maybe inspect the RGB sockets to see if something look suspicious. Another option is to ship it back for a replacement but this can be expensive depending where you live.
Hi Guys, sorry for taking so long to reply but I was away on work without the spider.
I have gone through the trouble shooting guide, with no success. As soon as power is applied to the spider the display turns white (full screen). No other messages are displayed, and no change occurs when running the code in the guide when the screen is touched.
The dip swithces are all in correct position after the firmware upgrade.
I have attached a picture of the display displaying the full white screen.
