Hi everyone, i don’t have much experience with .Net Gadgeteer, so i’m wondering if someone menaged to port FezAdbBridge example to fez Spider?
This example lets you control gadgeeter device from android phone via usb.
As I understand this example is for fez domino board.
Useful link http://code.google.com/p/robotfreak/wiki/FezBridge
I do not remember anyone saying they tried it with spider but It should be no problem.
Welcome to the community.
I cooked up this code but I get exemptions.
using System.Collections;
using Microsoft.SPOT.Touch;
//dodao
//using GHIElectronics.NETMF.FEZ;
using GHIElectronics.NETMF.USBHost;
//kraj
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace bridge3
public partial class Program
//dodao
static USBH_RawDevice usb;
static USBH_RawDevice.Pipe adbInPipe;
static USBH_RawDevice.Pipe adbOutPipe;
static Thread adbInThread; // polls the adb for data
const UInt32 A_SYNC = 0x434e5953;
const UInt32 A_CNXN = 0x4e584e43;
const UInt32 A_OPEN = 0x4e45504f;
const UInt32 A_OKAY = 0x59414b4f;
const UInt32 A_CLSE = 0x45534c43;
const UInt32 A_WRTE = 0x45545257;
private const ushort VALID_VID = 0x18D1;
private const ushort VALID_PID = 0x4E12;
private static bool initPhaseOneComplete;
private static bool initPhaseTwoComplete;
private static bool isReady;
private static bool busyWrite;
private static string hex = "0123456789ABCDEF";
private static string hostName = "host::fezbridge";
private static string portName = "tcp:4567";
static Thread glavni;
private UInt32[] AdbData = new UInt32[6];
private struct sAdbMessage
public UInt32 command;
public UInt32 arg0;
public UInt32 arg1;
public UInt32 dataLength;
public UInt32 dataCheck;
public UInt32 magic;
public int ByteSize
get { return 24; }
public byte[] ToArray()
byte[] data = new byte[ByteSize];
int offset = 0;
data[offset++] = (byte)(command); data[offset++] = (byte)(command >> 8); data[offset++] = (byte)(command >> 16); data[offset++] = (byte)(command >> 24);
data[offset++] = (byte)(arg0); data[offset++] = (byte)(arg0 >> 8); data[offset++] = (byte)(arg0 >> 16); data[offset++] = (byte)(arg0 >> 24);
data[offset++] = (byte)(arg1); data[offset++] = (byte)(arg1 >> 8); data[offset++] = (byte)(arg1 >> 16); data[offset++] = (byte)(arg1 >> 24);
data[offset++] = (byte)(dataLength); data[offset++] = (byte)(dataLength >> 8); data[offset++] = (byte)(dataLength >> 16); data[offset++] = (byte)(dataLength >> 24);
data[offset++] = (byte)(dataCheck); data[offset++] = (byte)(dataCheck >> 8); data[offset++] = (byte)(dataCheck >> 16); data[offset++] = (byte)(dataCheck >> 24);
data[offset++] = (byte)(magic); data[offset++] = (byte)(magic >> 8); data[offset++] = (byte)(magic >> 16); data[offset++] = (byte)(magic >> 24);
string datastring = "Out>> ";
for (int i = 0; i < data.Length; i++)
datastring += (ByteToHex(data[i]) + " ");
Debug.Print(datastring);
return data;
public static sAdbMessage Parse(byte[] data)
sAdbMessage msg = new sAdbMessage();
int offset = 0;
msg.command = (UInt32)(data[offset++] + (data[offset++] << 8) + (data[offset++] << 16) + (data[offset++] << 24));
msg.arg0 = (UInt32)(data[offset++] + (data[offset++] << 8) + (data[offset++] << 16) + (data[offset++] << 24));
msg.arg1 = (UInt32)(data[offset++] + (data[offset++] << 8) + (data[offset++] << 16) + (data[offset++] << 24));
msg.dataLength = (UInt32)(data[offset++] + (data[offset++] << 8) + (data[offset++] << 16) + (data[offset++] << 24));
msg.dataCheck = (UInt32)(data[offset++] + (data[offset++] << 8) + (data[offset++] << 16) + (data[offset++] << 24));
msg.magic = (UInt32)(data[offset++] + (data[offset++] << 8) + (data[offset++] << 16) + (data[offset++] << 24));
return msg;
};// private struct sAdbMessage
static sAdbMessage adbMsg = new sAdbMessage();
static sAdbMessage adbInMsg = new sAdbMessage();
static byte[] adbData = new byte[65];
timer.Tick +=<tab><tab>
timer.Start();
//kod iz Main()
glavni = new Thread(Glavna);
glavni.Start();
}//ProgramStarted
static void Glavna()
// Subscribe to USBH event. Izmenjeni event handleri
USBHostController.DeviceConnectedEvent += DeviceDisconnectedEvent;
USBHostController.DeviceDisconnectedEvent += DeviceDisconnectedEvent;
initPhaseOneComplete = false;
initPhaseTwoComplete = false;
isReady = false;
busyWrite = false;
// Sleep forever
//Thread.Sleep(Timeout.Infinite);
static void DeviceDisconnectedEvent(USBH_Device device)
isReady = false;
Debug.Print("Device disconnected");
//multicolorLed.TurnRed();
//print2();
static void DeviceConnectedEvent(USBH_Device device)
if (!initPhaseOneComplete)
usb = new USBH_RawDevice(device);
USBH_Descriptors.Configuration cd = usb.GetConfigurationDescriptors(0);
USBH_Descriptors.Endpoint adbEP = null;
USBH_Descriptors.Interface adbIF = null;
Debug.Print("[Device, Port " + usb.PORT_NUMBER + "]");
Debug.Print("Interface: " + usb.INTERFACE_INDEX);
Debug.Print("ID: " + usb.ID);
Debug.Print("Type: " + usb.TYPE);
Debug.Print("VID: " + usb.VENDOR_ID);
Debug.Print("PID: " + usb.PRODUCT_ID);
//multicolorLed.TurnGreen();
// look for HID class
for (int i = 0; i < cd.bNumInterfaces; i++)
Debug.Print("Device connected");
//print1();
adbIF = cd.interfaces[i];
if (adbIF.bInterfaceClass == 255)
Debug.Print(" === Interface ===");
Debug.Print(" Class: " + cd.interfaces[i].bInterfaceClass);
Debug.Print(" SubClass: " + cd.interfaces[i].bInterfaceSubclass);
Debug.Print(" Number: " + cd.interfaces[i].bInterfaceNumber);
Debug.Print(" Protocol: " + cd.interfaces[i].bInterfaceProtocol);
Debug.Print(" Type: " + cd.interfaces[i].bDescriptorType);
//stampanje na displeju
//display_T35.SimpleGraphics.Clear();
//display_T35.SimpleGraphics.DisplayText("=== Interface ===", Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 20);
// display_T35.SimpleGraphics.DisplayText(" Class: " + cd.interfaces[i].bInterfaceClass, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 35);
//display_T35.SimpleGraphics.DisplayText(" SubClass: " + cd.interfaces[i].bInterfaceSubclass, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 50);
// display_T35.SimpleGraphics.DisplayText(" Number: " + cd.interfaces[i].bInterfaceNumber, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 65);
// display_T35.SimpleGraphics.DisplayText(" Protocol: " + cd.interfaces[i].bInterfaceProtocol, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 80);
//display_T35.SimpleGraphics.DisplayText(" Type: " + cd.interfaces[i].bDescriptorType, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 95);
Thread.Sleep(2000);
for (int ep = 0; ep < adbIF.bNumberEndpoints; ep++)
adbEP = adbIF.endpoints[ep];
Debug.Print(" -- Endpoint --");
Debug.Print(" Attributes: " + adbIF.endpoints[ep].bmAttributes);
Debug.Print(" Address: " + adbIF.endpoints[ep].bEndpointAddress);
Debug.Print(" Type: " + adbIF.endpoints[ep].bDescriptorType);
Debug.Print(" Interval: " + adbIF.endpoints[ep].bInterval);
Debug.Print(" ");
//display_T35.SimpleGraphics.DisplayText(" -- Endpoint --", Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 20);
//display_T35.SimpleGraphics.DisplayText(" Attributes: " + adbIF.endpoints[ep].bmAttributes, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 35);
//display_T35.SimpleGraphics.DisplayText(" Address: " + adbIF.endpoints[ep].bEndpointAddress, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 50);
//display_T35.SimpleGraphics.DisplayText(" Type: " + adbIF.endpoints[ep].bDescriptorType, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 65);
//display_T35.SimpleGraphics.DisplayText(" Interval: " + adbIF.endpoints[ep].bInterval, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 80);
//display_T35.SimpleGraphics.DisplayText(" ", Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 95);
Thread.Sleep(2000);
switch (adbEP.bEndpointAddress)
case 133: // ADB data in
adbInPipe = usb.OpenPipe(adbEP);
adbInPipe.TransferTimeout = 0; // recommended for interrupt transfers
break;
case 5: // ADB data out
adbOutPipe = usb.OpenPipe(adbEP);
break;
initPhaseOneComplete = true;
initPhaseTwoComplete = true;
if (initPhaseTwoComplete)
isReady = true;
if (isReady)
usb.SendSetupTransfer(0x00, 0x09, 0x0001, 0x0000);
adbInThread = new Thread(AdbListening); // create the polling thread
adbInThread.Priority = ThreadPriority.Highest;
adbInThread.Start();
SendAdbMessage(A_CNXN, 16777216, 4096, hostName);
}//DeviceConnectedEvent
static void AdbListening()
int count = 0;
string datastring = "";
// Read every bInterval
Thread.Sleep(adbInPipe.PipeEndpoint.bInterval);
try
count = adbInPipe.TransferData(adbData, 0, adbData.Length);
catch (Exception ex)
Debug.Print(ex.ToString());
if (count == 24)
adbInMsg = sAdbMessage.Parse(adbData);
switch (adbInMsg.command)
case A_CNXN:
Debug.Print("In << CNXN " + adbInMsg.arg0.ToString() + "," + adbInMsg.arg1.ToString());
break;
case A_OPEN:
Debug.Print("In << OPEN " + adbInMsg.arg0.ToString() + "," + adbInMsg.arg1.ToString());
break;
case A_OKAY:
Debug.Print("In << OKAY " + adbInMsg.arg0.ToString() + "," + adbInMsg.arg1.ToString());
busyWrite = false;
break;
case A_CLSE:
Debug.Print("In << CLSE " + adbInMsg.arg0.ToString() + "," + adbInMsg.arg1.ToString());
SendAdbMessage(A_OKAY, adbInMsg.arg1, adbInMsg.arg0);
break;
case A_WRTE:
Debug.Print("In << WRTE " + adbInMsg.arg0.ToString() + "," + adbInMsg.arg1.ToString());
break;
default:
datastring = ByteArrayToString(adbData);
Debug.Print("In << (" + count.ToString() + ") " + datastring);
break;
else if (count > 0)
adbData[count] = 0;
switch (datastring)
case "device::":
SendAdbMessage(A_OPEN, 1, 0, portName);
break;
default:
string[] cmds = datastring.Split(';');
for (int i = 0; i < cmds.Length; i++)
string[] cmd = cmds[i].Split(':');
if (cmd.Length == 2)
switch (cmd[0])
case "x":
// servo1.SetPosition((byte)int.Parse(cmd[1]));
break;
case "y":
// servo2.SetPosition((byte)int.Parse(cmd[1]));
break;
break;
else if (count == 0)
//float value = myRanger.GetDistance_cm();
// Debug.Print("myRanger reading is: " + value.ToString());
// SendAdbMessage(A_WRTE, 1, 25, "a0:" + value.ToString() + ";");
Thread.Sleep(10);
}//AdbListening()
public static void SendAdbMessage(UInt32 st, UInt32 arg0, UInt32 arg1)
SendAdbMessage(st, arg0, arg1, (byte[])null);
public static void SendAdbMessage(UInt32 st, UInt32 arg0, UInt32 arg1, string str)
SendAdbMessage(st, arg0, arg1, StringToByteArray(str));
public static void SendAdbMessage(UInt32 st, UInt32 arg0, UInt32 arg1, byte[] data)
UInt32 crc = 0;
UInt32 cnt = 0;
if (data != null)
while (cnt < data.Length)
crc += data[cnt++];
cnt++;
Debug.Print("Out >> " + st.ToString() + "," + arg0.ToString() + "," + arg1.ToString());
adbMsg.command = st;
adbMsg.arg0 = arg0;
adbMsg.arg1 = arg1;
adbMsg.dataLength = cnt;
adbMsg.dataCheck = crc;
adbMsg.magic = st ^ 0xffffffff;
try
adbOutPipe.TransferData(adbMsg.ToArray(), 0, adbMsg.ByteSize);
if (data != null)
byte[] zdata = new byte[data.Length + 1];
data.CopyTo(zdata, 0);
adbOutPipe.TransferData(zdata, 0, zdata.Length);
}//SendAdbMessage
private static byte[] StringToByteArray(string str)
System.Text.UTF8Encoding enc = new System.Text.UTF8Encoding();
return enc.GetBytes(str);
private static string ByteArrayToString(byte[] data)
return new string(System.Text.Encoding.UTF8.GetChars(data));
public static string UIn16tToHex(UInt16 number)
return new string(new char[] { hex[(number & 0xF000) >> 12], hex[(number & 0xF00) >> 8], hex[(number & 0xF0) >> 4], hex[number & 0x0F] });
public static string ByteToHex(byte number)
return new string(new char[] { hex[(number & 0xF0) >> 4], hex[number & 0x0F] });
void print1()//stampanje na displeju
display_T35.SimpleGraphics.DisplayText("Device Connected", Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 20);
display_T35.SimpleGraphics.DisplayText("Device, Port [" + usb.PORT_NUMBER + "]", Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 35);
display_T35.SimpleGraphics.DisplayText("Interface: " + usb.INTERFACE_INDEX, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 50);
display_T35.SimpleGraphics.DisplayText("ID: " + usb.ID, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 65);
display_T35.SimpleGraphics.DisplayText("Type: " + usb.TYPE, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 80);
display_T35.SimpleGraphics.DisplayText("VID: " + usb.VENDOR_ID, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 95);
display_T35.SimpleGraphics.DisplayText("PID: " + usb.PRODUCT_ID, Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 110);
Thread.Sleep(2000);
void print2()//stampanje na displeju
display_T35.SimpleGraphics.DisplayText("Device disconnected", Resources.GetFont(Resources.FontResources.NinaB), GT.Color.White, 50, 20);
Thread.Sleep(2000);
void print3()
}// clas Program
}//bridge3
two things.
First, edit your post above (use the little pencil looking icon at the top of your post). Then highlight all your code, then hit the 101010 icon at the TOP of your post (not the coloured ones). Then re-submit it… this will allow the code to be formatted better.
Second, giving us a code sample like this, and saying “but I get exemptions(sic)” isn’t very helpful. Tell us about the exceptions you get, and where in your code they come up? Have you stepped into your code and see what goes on? What does work and what doesn’t? And have you tried breaking down your code into usable chunks and proven each one works?
Oh and a third too, it’d be great if you can update your forum identity so we know who you are and so we can stop thinking of you as just a number
//Program.cs
namespace bridge3
private enum Status
Idle, Ahead, Back, TurnRight, TurnLeft, Rotate
private enum RoverDirection
None = 0,
Ahead = 1,
Back = 2,
static RoverDirection roverDirection;
static bool pomocna = false;
static Status currentStatus;
static Status newStatus;
static Int16 Xdata;
static Int16 Ydata;
public UInt32 arg0;
public UInt32 arg1;
public int ByteSize
get { return 24; }
int offset = 0;
return data;
int offset = 0;
return msg;
multicolorLed.BlinkOnce(GT.Color.Orange);
multicolorLed.GreenBlueSwapped=true;
USBHostController.DeviceConnectedEvent += new USBH_DeviceConnectionEventHandler(USBHostController_DeviceConnectedEvent);
USBHostController.DeviceDisconnectedEvent += new USBH_DeviceConnectionEventHandler(USBHostController_DeviceDisconnectedEvent);
isReady = false;
busyWrite = false;
// Sleep forever
}//ProgramStarted
void USBHostController_DeviceConnectedEvent(USBH_Device device)
string interf = adbIF.bInterfaceClass.ToString();
Debug.Print(interf);
Debug.Print(" ");
string adbEPbEndp = adbEP.bEndpointAddress.ToString();
Debug.Print(adbEPbEndp);
case 132: // ADB data in old value 133, 132 for 2.2, 130 for 4.0.4
break;
case 133: // ADB data in old value 133, 132 for 2.2, 130 for 4.0.4
break;
case 130: // ADB data in old value 133, 132 for 2.2, 130 for 4.0.4
break;
case 3: // ADB data out old value 5, 3 for 2.2, 2 for 4.0.4
break;
case 5: // ADB data out old value 5, 3 for 2.2, 2 for 4.0.4
break;
case 2: // ADB data out old value 5, 3 for 2.2, 2 for 4.0.4
break;
isReady = true;
if (isReady)
usb.SendSetupTransfer(0x00, 0x09, cd.bConfigurationValue, 0x0000);
void USBHostController_DeviceDisconnectedEvent(USBH_Device device)
adbInThread.Suspend();
isReady = false;
static void menjac() //direction chooser
if(Ydata<50)
newStatus = Status.Ahead;
roverDirection = RoverDirection.Ahead;
multicolorLed.TurnWhite();
pomocna = false;
if(Ydata >120)
newStatus = Status.Back;
roverDirection = RoverDirection.Back;
pomocna = false;
if(Ydata>50 && Ydata<120)
pomocna = true;
if (Xdata > 60 && Xdata < 110 && pomocna)
newStatus = Status.Idle;
roverDirection = RoverDirection.None;
multicolorLed.TurnOff();
if(pomocna && Xdata>110)
newStatus = Status.TurnRight;
if (pomocna && Xdata<60)
newStatus = Status.TurnLeft;
multicolorLed.TurnBlue();
Movement();
static void Movement() //motor driving
if (currentStatus != newStatus)
int speed = 50;
int currentDirection1 = 0;
int currentDirection2 = 0;
switch (newStatus)
case Status.Idle:
currentDirection1 = currentDirection2 = 0;
break;
case Status.Ahead:
currentDirection1 = currentDirection2 = 1;
break;
case Status.Back:
currentDirection1 = currentDirection2 = -1;
break;
case Status.TurnRight:
speed = 100;
if (roverDirection == RoverDirection.Ahead)
else if (roverDirection == RoverDirection.Back)
break;
case Status.TurnLeft:
speed = 100;
currentDirection1 = 1;
currentDirection1 = -1;
break;
case Status.Rotate:
speed = 100;
break;
default:
break;
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor1, speed * currentDirection1);
motorControllerL298.MoveMotor(MotorControllerL298.Motor.Motor2, speed * currentDirection2);
currentStatus = newStatus;
int count = 0;
try
if (count == 24)
case A_CNXN:
break;
case A_OPEN:
break;
case A_OKAY:
busyWrite = false;
break;
case A_CLSE:
break;
case A_WRTE:
break;
default:
break;
else if (count > 0)
adbData[count] = 0;
switch (datastring)
case "device::":
break;
default:
switch (cmd[0])
case "x":
Debug.Print("X:"+(cmd[1]));
if (cmd[1] != "")
Xdata = System.Convert.ToInt16(cmd[1]);
// menjac();
break;
case "y":
Debug.Print("Y:"+(cmd[1]));
if (cmd[1] != "")
Ydata = System.Convert.ToInt16(cmd[1]);
menjac();
break;
break;
// float value = 5;
Thread.Sleep(10);
UInt32 crc = 0;
UInt32 cnt = 0;
if (data != null)
crc += data[cnt++];
cnt++;
adbMsg.arg0 = arg0;
adbMsg.arg1 = arg1;
try
if (data != null)
//Program.generated.cs
// <auto-generated>
// This code was generated by the Gadgeteer Designer.
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
// </auto-generated>
using Gadgeteer;
namespace bridge3
public partial class Program : Gadgeteer.Program
// GTM.Module definitions
static Gadgeteer.Modules.GHIElectronics.UsbHost usbHost;
static Gadgeteer.Modules.GHIElectronics.Display_T35 display_T35;
static Gadgeteer.Modules.GHIElectronics.MotorControllerL298 motorControllerL298;
static Gadgeteer.Modules.GHIElectronics.MulticolorLed multicolorLed;
//Important to initialize the Mainboard first
Mainboard = new GHIElectronics.Gadgeteer.FEZSpider();
Program program = new Program();
program.InitializeModules();
program.ProgramStarted();
program.Run(); // Starts Dispatcher
private void InitializeModules()
// Initialize GTM.Modules and event handlers here.
usbHost = new GTM.GHIElectronics.UsbHost(3);
multicolorLed = new GTM.GHIElectronics.MulticolorLed(8);
display_T35 = new GTM.GHIElectronics.Display_T35(14, 13, 12, 10);
motorControllerL298 = new GTM.GHIElectronics.MotorControllerL298(11);
I solved all problems, these are my codes if someone wants to use it.
Please post the code on codeshare. Extra credit for a video showing it in action
