Hello guys,
I’ve noticed the spider never fired the Network down event correctly before and set that issue aside until i figure out how to reproduce it correctly and today i think i found a way…
basically if i have the network Plugged in and Powered the spider, waited to get an IP, then unplug the cable. the down event never fires… if i plug the cable back again and waited a few seconds the Network up fires now unplug the cable and boom the network down fires correctly and it keeps working properly going forward…
so if the cable is plugged in when the spider is powered the first network down never fires…
Second test.
if i remove the cable and power the spider, and wait for the spider to start… next i plug the cable, the network up fires correctly now i unplug the cable and the network down fire correctly and works as expected…
So if the network cable is unplugged when the spider is powered up everything seem to work as expected…
