Hi, trying to connect a device to SPI2. But which pin (ChipworkX.Pin) do I use when SPI.Configuration.
PB30/MISO
PB31/MOSI
PB29/SCK
I noticed on the FEZ documentation its got FEZmini.Pin.Di2x.
PB30/MISO
PB31/MOSI
PB29/SCK
The configuration doesn’t take pins, only SPI1 or SPI2. I am not sure what you need.
Oh sorry,
I have a module that, which I have connected to SPI2 on the board. I now want to read/write from it.
This is how far I got with it. But not sure where I go from here…
SPI.Configuration sd = new SPI.Configuration((Cpu.Pin)ChipworkX.Pin.
That first parameter is the pin for ChipSelect (SSEL or CS), the other pins are automatically selected when you use SPI2
The book should explain a bit more on how SPI works
Yes, sorry I totally forgot about the select pin.
I’m plugging this in
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en537238
again
Why are you plugging SD socket on SPI bus?! ChipworkX already supports SD cards and there is one on the development system
I keep getting
An unhandled exception of type ‘System.IO.IOException’ occurred in Microsoft.SPOT.IO.dll when trying to access the sd card. So, I’m trying a SD module I have.
More detail is in another forum
http://www.tinyclr.com/forum/18/1976/
