I was tring to use this code:
http://code.tinyclr.com/project/320/sparkfun-32-rgb-led-strip-wic/
On the FEZ Mini. In the driver, it mentions that it’s coded for Di11 and Di13 , which I assume will correspond to UEXT8 and UEXT9 on the Fez Mini.
But when I tried to do it, absolutely nothing happens (forgive me, I don’t have a logic analyzer so I don’t know if nothing happens, it just the LEDs don’t do anything but lamp the last one on the string, which it does anyway with power supplied and the other 2 pins diconnected).
I also tried to change the code for the SPI configuration from:
_cfg = new SPI.Configuration (Cpu.Pin.GPIO_NONE, false, 0, 0, false, true, 2000, module);
to:
_cfg = new SPI.Configuration ((Cpu.Pin)FEZ_Pin.Digital.UEXT10, false, 0, 0, false, true, 2000, module);
Is this right? Am I doing something wrong? It’s driving me crazy.
Can someone point me in the right direction on how to do Software SPI and I could move it different pins to see if that is the issue?
Thanks,
Tom
