SPI maxO communication
Just wondering how I can send data through SPI to the maxO module, and then read back which pins are set. I understand that there are methods which already do that but I was hoping to use SPI for this.
Here is my configuration that I wrote (which I also believe doesn’t work). Any help would be very beneficial.
using Gadgeteer.Interfaces;
GT.Socket _socket = GT.Socket.GetSocket(6, true, null, null);
ConfigSPI = new SPI.Configuration(false, 0, 0, false, true, 1000);
SPI MySPI = new SPI(_socket, ConfigSPI, SPI.Sharing.Shared, maxO);
I am using the Spider board and I connected the maxO module to socket 6.
It is output only
Sorry, the maxO module is output only? (i.e. I cannot write to it)
Otherway around isn’t it???
output, you can write to it but you can’t read from it
Max O = Maximum Outputs.
ok, so how would I go about writing to the module? The following code only set the rightmost pin to high:
using Gadgeteer.Interface;
byte[] tx_data = { 0xAA, 0xAA, 0xAA, 0xAA };
MySPI.Write(tx_data);
Just curious why are you using SPI directly instead of using Gadgeteer driver? Is there a problem?
No particular reason, more out of curiosity than anything. I guess proof of concept?
Ok. That module uses some extra pins that you have to set to a certain state (enable pin for example) for the module to work properly. Just using SPI is not enough. Take a look at module’s source code on codeplex, if you want to rewrite it, or just use it as is.
Ah, ok - no real direct way of doing this I see. I will take a look.
No, you still will be using SPI. You just need to take care of other pins on that socket as well:
/// <summary>
        /// Writes the full array of data to the registers.
        /// </summary>
        /// <param name="arr"></param>
        public void WriteArray(byte[] arr)
            if (!reSized)
                throw new Exception("No boards have been initialized! Please indicate how many modules are chained before writing");
            if (arr.Length != data.Length)
                throw new Exception("Passed in array not the same size as the number of registers!");
            Enable.Write(true);
                byte[] reversedArr = new byte[arr.Length];
                Array.Copy(arr, reversedArr, arr.Length);
                for (int i = 0; i < reversedArr.Length; i++)
                    reversedArr[i] = arr[data.Length - i - 1];//(byte)(~reversedArr[i]);
                spi.Write(reversedArr);
                Array.Copy(arr, data, arr.Length);
            Enable.Write(false);
Where Enable is:
Enable = new GTI.DigitalOutput(socket, Socket.Pin.Three, false, this);
Ah i see. The Enable Pin was what really got me. Thanks for the response.
You are welcome!
