The situation I have currently is that I am trying to send data through a SPI bus to a slave device and I am noticing that “sometimes” not all the data I am expecting is present on the analyzer.
Analyzer <----- ARINC bus -------- Holt IC 3585 <------ SPI bus -----> USbizi144chipset
So I am wondering if my spi configuration is setup wrong? Do I need to monitor something such as the SPI busy pin or some other caveat for high volumes of SPI writes.
Thanks for any help in advance.
Here is the information I have:
Datasheet for the HoltIC 3585 HI-3585 / HI-3586 - Holt Integrated Circuits, Inc.
I am using the USBizi144 chipset on a custom layout.
Code Snippets:
SPI.Configuration SPIConfiguration = new SPI.Configuration((Cpu.Pin)FEZ_Pin.Digital.IO9, // Chip Select Pin IO26/P0.16
false, // IC is accessed when chip select is low
0, // Setup Time
0, // Hold Time
false, // Idle : false = Idle Low : true = Idle High
true, // Clock Edge : true = rising edge / false = falling edge
4000, // 4 MHZ clock speed
SPI.SPI_module.SPI1); // Use 2nd SPI bus
byte[] ARINC_429_TX_FIFO_DATA = new byte[5];
// The writeTxFIFO will load a ARINC 429 word into the Tx FIFO
// and transmit the ARINC message instantly
// if the Control Register bit 13 is set to 1.
// If the Control Register bit 13 is set to 0, ARINC messages
// will be loaded into the Tx FIFO and wait for the OP Code 0x12 (writeTxImmediate) before broadcasting..
public void writeTxFIFO(byte[] arincWord)
ARINC_429_TX_FIFO_DATA[0] = OP_CODES.WRITE_TO_TX_FIFO;
Array.Copy(arincWord, 0, ARINC_429_TX_FIFO_DATA, 1, 4);
spi_device.Write(ARINC_429_TX_FIFO_DATA);
