Guys,
I hope someone is able to help as I’m already trying to get this to work since 14 days. ![]()
The SPI device in question is a HopeRF RFM12B transceiver.
The problem is that I only receive the first 2 bytes, which contains some flags, an ID and the length of the payload that should be coming in after these 2 bytes.
The datasheet mentions this regarding the SPI interface:
[quote]
Commands to the transmitter are sent serially. Data bits on pin SDI are shifted into the device upon the rising edge of the clock on
pin SCK whenever the chip select pin nSEL is low. When the nSEL signal is high, it initializes the serial interface. All commands
consist of a command code, followed by a varying number of parameter or data bits. All data are sent MSB first (e.g. bit 15 for a 16-bit command). Bits having no influence (dont care) are indicated with X. Special care must be taken when the microcontrollers built-in hardware serial port is used. If the port cannot be switched to 16-bit mode then a separate I/O line should be used to control the
nSEL pin to ensure the low level during the whole duration of the command or a software serial control interface should be
implemented.[/quote]
I’m a bit puzzled by the 16-bit mode. Is the SPI port on the USBizi in 16-bit mode by default or is there a setting I’m overlooking?
I’m initializing the SPI port as follows:
//In Main():
rfm = new RFM12B_3(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di5, (Cpu.Pin)FEZ_Pin.Interrupt.Di6);
rfm.OnDataReceived += new RFM12B_3.OnDataRecievedHandler(rfm_OnDataReceived);
rfm.Init(31, Band.RF868MHZ, 4); //This nodeid=31 and group 4
//The Driver:
public RFM12B_3(SPI.SPI_module spiModule, Cpu.Pin spiSelectPin, Cpu.Pin rfmInterruptPin)
spiConfig = new SPI.Configuration(spiSelectPin, false, 0, 0, false, true, 1000, spiModule);
_spiPort = new SPI(spiConfig);
_myinterruptPort = new InterruptPort(rfmInterruptPin, false, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeLow);
_myinterruptPort.OnInterrupt += new NativeEventHandler(_interruptPort_OnInterruptRF12);
_myinterruptPort.DisableInterrupt();
public void Init(uint nid, Band b, uint g)
group = g;
nodeid = nid;
usedband = b;
InitModuleJee();
reset();
private void reset()
RFXX_WRT_CMD(RF_STATUS_REG);
RFXX_WRT_CMD(RF_RECEIVER_ON);//!er,!ebb,ET,ES,EX,!eb,!ew,DC
////Init FIFO
RFXX_WRT_CMD(RF_ENABLE_FIFO);
RFXX_WRT_CMD(RF_CLEAR_FIFO);
private void InitModuleJee()
RFXX_WRT_CMD(RF_SLEEP_MODE);
RFXX_WRT_CMD(RF_TXREG_WRITE);
while (_myinterruptPort.Read() == false)
ushort config = (ushort)(0x80C7 | ((int)usedband << 4));
RFXX_WRT_CMD(config); // EL (ena TX), EF (ena RX FIFO), 12.0pF
RFXX_WRT_CMD(0xA640);
RFXX_WRT_CMD(0xC606); // approx 49.2 Kbps, i.e. 10000/29/(1+6) Kbps
RFXX_WRT_CMD(0x94A2); // VDI,FAST,134kHz,0dBm,-91dBm
RFXX_WRT_CMD(0xC2AC); // AL,!ml,DIG,DQD4
if (group != 0)
RFXX_WRT_CMD(RF_CLEAR_FIFO); // FIFO8,2-SYNC,!ff,DR
RFXX_WRT_CMD((ushort)(0xCE00 | group)); // SYNC=2DXX;
RFXX_WRT_CMD(0xCA8B); // FIFO8,1-SYNC,!ff,DR
RFXX_WRT_CMD(0xCE2D); // SYNC=2D;
RFXX_WRT_CMD(0xC483); // @ PWR,NO RSTRIC,!st,!fi,OE,EN 0xC483
RFXX_WRT_CMD(0x9850); // !mp,90kHz,MAX OUT
RFXX_WRT_CMD(0xCC77); // OB1,OB0, LPX,!ddy,DDIT,BW0
RFXX_WRT_CMD(0xE000); // NOT USE
RFXX_WRT_CMD(0xC800); // NOT USE
RFXX_WRT_CMD(0xC049); // 1.66MHz,3.1V
if ((nodeid & NODE_ID) != 0)
_myinterruptPort.EnableInterrupt();
The Receiving part:
void _interruptPort_OnInterruptRF12(uint data1, uint data2, DateTime time)
while (_myinterruptPort.Read() == false) //We can only read the FIFO when the irq line is LOW
status = RFXX_WRT_CMD(RF_STATUS_REG);
printstatus(status);
HDR = (byte)(RFXX_WRT_CMD(RF_RX_FIFO_READ) & 0x00FF); //Contains CTL,DST,ACK and NodeID
LEN = (byte)(RFXX_WRT_CMD(RF_RX_FIFO_READ) & 0x00FF);
CTL = ((HDR >> 5) & 0x04) != 0; //Control bit used with ACK
DST = ((HDR >> 5) & 0x02) != 0; //if DST is false, ID is sending Node ID, else target Node ID
ACK = ((HDR >> 5) & 0x01) != 0; //if sender wants an ACK
NodeID = (HDR & RF12_HDR_MASK); //Node ID
payload = new byte[LEN]; //Buffer to recieve the data
for (int x = 0; x < LEN; x++)
payload[x] = (byte)ReadBuffer2(); // (byte)(RFXX_WRT_CMD(RF_RX_FIFO_READ) & 0x00FF);
OnDataReceived(payload);
reset();
uint data_in;
private ushort ReadBuffer2()
data_in = RFXX_WRT_CMD(0x0000); //status register
if ((data_in & 0x8000) != 0) // if FIFO full, read a byte
data_in = RFXX_WRT_CMD(0xB000);
return (ushort)(data_in & 0x00FF);
return 0;
private void resetfifo()
ushort[] _readBuf = new ushort[1];
ushort[] _writeBuf = new ushort[1];
private ushort RFXX_WRT_CMD(ushort cmd)
_writeBuf[0] = cmd;
_spiPort.WriteRead(_writeBuf, _readBuf);
return (_readBuf[0]);
The problem is that when i want to read the actual data (payload) it only returns 0’s.
I’m wondering if the SPI port is setup correctly? If it is, could i be looking here at a timing issue? Or is the 16-bit mode bugging me here? Or maybe something else I’m overlooking.
For completeness I’ll add a link to the transceiver’s datasheet: [url]Technical Resource Search - Silicon Labs
Many thanks to those willing to take a look at this.
Greetings,
Eric
