I’m trying to interface my FEZ Panda with an ATtiny2313 via SPI. The ATtiny is acting as an encoder counter that reports counts via SPI.
I’ve clocked it as slow as it will go (200 kHz apparently), but there is still bit-level corruption. Here the ATtiny is responding to a command with a single byte count, where the count should be staying constant:
223
223
223
191
223
223
191 = 10111111
223 = 11011111
This is the Panda code I’m using
namespace PandaTest
// Blink board LED
bool ledState = false;
OutputPort led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, ledState);
SPI.Configuration spiConfig = new SPI.Configuration(
(Cpu.Pin)FEZ_Pin.Digital.Di9, false, 0, 0,
false, true, 200, SPI.SPI_module.SPI1,
(Cpu.Pin)FEZ_Pin.Digital.Di10, true);
SPI spi = new SPI(spiConfig);
byte[] spi_tx = new byte[1],
spi_rx = new byte[1];
// Sleep for 500 milliseconds
Thread.Sleep(500);
byte channel = 0;
spi_tx[0] = (byte)((1 << 2) | channel);
spi.Write(spi_tx);
Thread.Sleep(1);
spi.WriteRead(spi_tx, spi_rx);
Debug.Print(spi_rx[0].ToString());
// toggle LED state
ledState = !ledState;
led.Write(ledState);
Both Panda and ATtiny are set to CPOL=0, CPHA=0 (clock idle state 0, reads data on the rising edge). ATtiny is configured as a slave, and it is definitely asserting the BUSY signal in time (the byte is getting sent, just corrupted somehow).
Adding the Thread.Sleep(1); didn’t change results
Any ideas what’s going on here?
