Are these passthrough? do I hook up the Hat to SPI0?
Which hat and which pins?
@ Gus - Fez hat for rpi2.
If I want to use SPI or I2C, where do i Connect?
Both are labeled right on the hat. Right in the middle.
@ Gus - Thanks, I guess the question was very badly formulated to begin with on my end.
I guess I only wondered if this is a straight pass-through of cable from the pins on the RPI to the middle of the Fez Hat
As for “Where do I connect” question, that was related to the SDK which I hadn’t looked long enough at. For those, I’ll just do what I’ve always done on the RPI, only connect them on the board instead
Sorry for the noise
Yes straight from the original pins. We just labeled them and made them easier to access.
